Question about Apple Mac mini G4 Desktop
Stuck on initial screen on power up
When turning on my mac I get the initial gray screen with the apple logo and a spinning wheel. Usually after a few seconds the computer fully loads, but now the wheel just keeps spinning for a very long time.
What should I do?
  • 34 Answers
Sounds like your hard drive died, you should take it into a repair shop unless you know someone that can replace the drive and re-install OS X for you. you computer uses a 2.5" laptop hard drive.
Posted on Jan 29, 2009
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
When i start up my imac screen goes white with apple logo ang loading wheel then after that a blue screen,then just stays on blue screen
Thanks for asking your question with Fixya Support. I will be glad to assist you.
What I would recommend is that you try to acquire a USB keyboard, for this issue, because it will open the way for many troubleshooting options for such an issue like this.
If you can get temporary use of a USB keyboard, you can try any of these options:
Option 1:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if it is not already shutdown (turned off)
•You will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start-up sound for the second time.
• Release the keys and allow your iMac to start up.
If that does not work and you still reach a blue screen when you reboot, try this option:
Option II
Here is a simple procedure that I recommend you try:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, and some input/output as it relates to the computer sleeping.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer
If you still reach a blue screen, now you will need to go to this alternative process:
Option III
Try taking your Mac into Safe Mode in order to remove a possible folder(s) which may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop enviroment the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your iMac normally and see if you can access your normal User desktop environment.
One of these three options should help return you back to your main desktop.
If it does not, please let me know.
Thanks!
-The MacTechTrainer
Sep 10, 2012 | Apple 24" iMac Desktop
My computer is stuck on the gray screen with the apple logo and spinning wheel only, please help I've spent over 8 hours trying to fix this Thank you very much!
you probably will have to insert your setup cd and reinstall you operating system---does "leopard" or "tiger" sound familiar?
Feb 14, 2011 | Apple MacBook PC Notebook
My iTouch is frozen on the apple logo, with a little loading circle frozen on top of that. there is a little broken line of different colors, very thin, about a centimeter from the top of the screen. I've...
Iv only seen that line with a jailbreak found at jailbreak me dot com... I'm not saying you jailbroke your phone but if it is that you might just be able to restore your iPod from your computer. Try it either way.
Dec 16, 2010 | Apple iPod touch
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Mac book only shows apple logo when turned on
This could be an issue where you may have a few Startup items in your StartupItems folder in your System Library which may be affecting your Macbook's startup.
So I recommend you boot your Mac into Safe Mode to see if you can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Allow the Mac to continue booting up. Also this may take a little while.
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps!
Regards,
-Mactechtrainer
Jan 28, 2010 | Apple MacBook Pro Laptop Computer with...
Computer shut down during update
go to apple's website.Or fomat it and install all the programs
Sep 18, 2009 | Apple MacBook Mac Notebook
Mac Laptop has black screen
Try starting in safe mode, this usually bypasses the graphics drivers, which could be in a funky state:
To start up in safe mode
Shut down your computer and wait 10 seconds.
You should press the Shift key as soon as possible after your hear the startup tone, but not before.
Jul 31, 2008 | Apple MacBook Pro Notebook
Apple Mac mini G4 Desktop Logo
322 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
