Printer fails to print - error code -50
HP Deskjet 1220C connected directly by USB cable to iMac running OS X 10.5.6 fails to print from Mac programs (mail, pages) and gives error code -50 and drop down states printer busy when I try a test. When opening the Printer box in Mac it states 'Printer reday idle' and when I press 'Print' it states 'connecting' etc, etc, and then says 'fatal error' and returns to 'Printer Ready'. The Mac also has VMWare Fusion with MS XP and the printer works fine on MS Word etc. This is the only printer connected to the iMac
  • 1 more comment
  • john_e_wiles Feb 05, 2009
    It's OK! Apparently when running both Fusion (XP) and Mac Fusion will take priority. Therefore the Mac programs will show 'Printer busy' even when the printer is in fact ready. The solution is simply to click on 'Disconnect printer' at the bottom right hand corner of the fusion screen whenever you need to use the printer with a Mac program. Thanks to those who offered possible solutions.
  • M Norwood May 11, 2010
    Have you tried updating the Printer Drivers for the Mac side of things?
  • Anonymous Mar 28, 2014
    Error code 1712 Finder won't open - mac os 10.9.2
  • 481 Answers
From System Preferences / Printers, delete the printer completely.
If you have the driver installer for the driver you are using, re-launch it and choose the "uninstall" option. If not, you will have to rip out a lot of code by hand -- you will have to search HP's website for the page on how to manually remove traces of old Mac HP drivers.
Download the latest driver for your printer from the HP website. Install if carefully.
After rebooting, go to System Preferences / Printers and re-define the printer. Make sure you use the HP driver, not any of the generic drivers.
This ought to clear the problem.
Posted on Sep 19, 2009
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
Oct 28, 2013 | HP DeskJet 1220c InkJet Printer
Deskjet F2180 not printing with Mac OS X 10.4.11
When you installed the new software did you delete your old print setup in the printer preferences as it may be conflicting with the new driver. I would delete all appropriate hp F2180 printers from the printer preferences and then install the print software again. When you do that does your printer show up? if it does not show up there could be a problem with the usb cable or the usb port on the back of your mac, swop it into another usb port, if it still does not show up, use a different usb cable. Hope this helps.
Jan 09, 2012 | Office Equipment & Supplies
HP Deskjet 1220C Drivers for win 7 x64
Click this link
For instruction information for windows 7 operating system.
Read and Do that step by step instruction of HP website.
Jun 28, 2011 | HP DeskJet 1220c InkJet Printer
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
Printing stops at the middle
3 weeks ago i gt same problm.,just check usb cable with avometer or other, 2 make sure all 4 small cable inside conect properly each pole.or replace it with new problms solved.
Mar 16, 2009 | HP DeskJet 1220c InkJet Printer
Problems printing on HP 1220c using vista
1.make sure printer is in ready condition(lamp indicator not blinking) and conected.if blinking thers problems with printer ,catridge or something
2.contrlol panel>printer chek status of printer.if 'offline' its not properly conected.if 'ready' then> hp diagnostic tool from hp website and run will detect the problem and follow the instruction.if not work>
4.uninstal driver and printer,reinstal it.if not work>
5.try on another comptr.
Mar 04, 2009 | HP DeskJet 1220c InkJet Printer
Mfc-210c will not print
do you run mac or win as a pc system?
for pc: delete all drivers by help of the agressive remover tool (see: choose your country, your mfc and download the drivers needed).
Take mfc from power outlet and disconnect from usb port. Run the above mentioned procedures and reinstall the drivers again. When asked, replug mfc to power again.
Connect the usb cable directly to pc!!!!!!
If you run mac I cant give you an adivece yet, because I m not common to mac os yet (end of year I will know better cause will get an imac then, sorry!)
Apr 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
