Question about Toshiba Satellite X200-AA3 Notebook
How I go to bios setup
The system 32 snd.exe is not having a device
Im trying to reformat my sAmsung laptop but i cannot find the cdrom to first boot, only the hardisk and windows boot manager will appear!.,.thnkx
You may have to go into the setup (BIOS) and check to see that the CD-ROM is enabled as a boot device. Some BIOS allow you to disable the CD-ROM as a boot device. It would not be listed in the boot manager if that were the case.
Dec 22, 2014 | Samsung Computers & Internet
I keep getting setup error which says You cannot install the 64 bit version of Office 2010 because you have 32-bit Office products installed. These 32-bit products are not supported iwht 64-bit insta
If you have downloaded it as a free trial, go to the office page and get the office for your system.
Remember to check what system is yours: Start/Computer/View System properties/information/32/64 bit system.
Apr 14, 2013 | Microsoft Office Professional 2007 Full...
How do i enter setup in AST PREMIUM/286 WITH PHOENIX 80286 ROM BIOS VERSION 3.02?
Some older 286's bios don't have user setup on the chip. You have to write to the chip using software. Search for gsetup.exe, copy it to a dos boot disk and run it.
Jul 18, 2011 | Computers & Internet
How do i rinstall sound device
First find out which device is suitable "matching" to your system (e.g Realtek). Suppose if you have CD/DVD then insert the CD/DVD in your Drive. Explore or open it and find out setup.exe to install it to your system. or Start>Run>"type the current Drive name of your system to insert CD/DVD drive followed by setup.exe" example E://setup.exe And wait till the install completed and then reboot "restart" your system and see.
All the Best!
Sep 25, 2010 | Microsoft Computers & Internet
I can't get the sound for anything. What do I have to do to get it back?
though itz unclear to me of wat os u r using..
assuming that u r using win xp pro sp2..n directx installed..
check if Audio device is enabled in bios..
howevr, download microsoft kb888111 update n install it..u need to re-install or update the device driver (may b manually)..logon to internet n seek the package/audio driver..along wid the company, there will b a list of such site n driver download links if u search by the model name on a search engine (like google)..
download them onto a location; if the driver is in a zip format, unzip it,if itz in .exe form, just run it; if done manually it'll ask for the correct driver and location; relocate the path and a .inf file (wat it'll ask for)....goto the device manager n verify, if installed properly..!!
also download n install k-lite mega codec pack....
if not fixed try using a standby pci snd card (in such case it'll b a confirmed case of ur system board is likely to b defective)..
but always better to consult ur system admin/vendor....
Nov 12, 2009 | Microsoft Windows XP Home Edition
I just purchased my 2nd Asus My Pal A626 Pocket PC. And I cannot run the setup program on any of my 5 computers. It tells me I need Flash 8.x or higher and I have Flash 10.x or it says I may have a...
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
Nov 03, 2009 | ASUS MyPal A626
I have no sound in my laptop
enter in your bios setup ten reset all settigns to factory defaults.then check also check proper drive rinstalled 1st remove old drivers then install again let me know if u need driver sonload link.
Jan 29, 2009 | Toshiba Satellite X200-AA3 Notebook
Problem related to bios setup
it doesn't matter. if you are running 32 bit operating ssytem. you can get majority of the hardware drivers.
however, if the operating sytem is 64-bit, you can't run it on a 32-bit machine. that is what determine by the BIOS.
since you have install the sytem and it seems running fine. I would just leave it alone.
Nov 13, 2008 | Computers & Internet
Boot sequence manual
When you hit the power button on your computer a whole lot of stuff happens. We call this the boot process. In the days when I first started using computers there was literally a "boot disk", a floppy (5.25" not a 3.5") disk that told the system where to go and what to do so that the operating system would start up. Since then the boot sequence has become somewhat more complicated. So let me take you thru the steps the computer takes to get started. For my example I'm going to use a Windows XP system.
  1. First is the POST, this stands for Power On Self Test, for the computer. This process tests memory as well as a number of other subsystems. You can usually monitor this as it runs each test. After that is complete the system will run POST for any device that has a BIOS (Basic Input-Output System). An AGP has its own BIOS, as do some network cards and various other devices.
  2. Once the POST is complete and the BIOS is sure that everything is working properly, the BIOS will then attempt to read the MBR (Master Boot Record). This is the first sector of the first hard drive (called the Master or HD0). When the MBR takes over it means that Windows is now in control.
  3. The MBR looks at the BOOT SECTOR (the first sector of the active partition). That is where NTLDR is located, NTLDR is the BOOT LOADER for Windows XP. NTLDR will allow memory addressing, initiate the file system, read the boot.ini and load the boot menu. NTLDR has to be in the root of the active partition as do NTDETECT.COM, BOOT.INI, BOOTSECT.DOS (for multi-OS booting) and NTBOOTDD.SYS (if you have SCSI adapters)
  4. Once XP is selected from the Boot Menu, NTLDR will run NTDETECT.COM, BOOT.INI and BOOTSECT.DOS to get the proper OS selected and loaded. The system starts in 16-bit real mode and then moves into 32-bit protected mode.
  5. NTLDR will then load NTOSKRNL.EXE and HAL.DLL. Effectively, these two files are windows XP. They must be located in %SystemRoot%System32.
  6. NTLDR reads the registry, chooses a hardware profile and authorizes device drivers, in that exact order.
  7. At this point NTOSKRNL.EXE takes over. It starts WINLOGON.EXE that in turn starts LSASS.EXE, this is the program that display the Logon screen so that you can logon.
Nov 05, 2008 | Computers & Internet
Drivers
I'm not sure if I understand clearly, you are having problems getting the driver cd to install?
Try a manual run by inserting the cd then go to Start>Run- then browse for the drive where the cd is located and then select open, you may need to choose install.exe of there isn't a setup.exe option
Jan 02, 2008 | Nvidia Geforce FX 5200 Graphic Card
Toshiba Satellite X200-AA3 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
