Question about Compaq (A7486A)
Compaq SR2011WM The power button is just flashing. Computer will not come on?
    Problem Solver:
  • 16 Answers
Most common reason for this would be defective power supply, if it is less than 1 year old, may still be under warranty. If older then you can usually find replacement power supply $40+ at local computer store. Not to difficult to replace, average tech could swap it in less than 15 minutes. Can test it with one of these: http://www.antec.com/Detail.bok?no=429
Posted on Jul 27, 2007
SOURCE:
I have a Compaq Presario SR2011WM which powered down on me. I get a solid light in the back and when I hit the power button I get a solid light on the front also which will not shut off unless I unplug it....
Well, unplugging something (I'm not quite clear on what you unplugged), especially if it supplies power to the processor usually doesn't fix things. If you mean the plug that looks like http://www.pcguide.com/byop/diagrams/figure9.jpg then it helps supply power to the motherboard, and I'm not sure what unplugging it would fix but it is more likely a motherboard issue than a processor issue if unplugging it fixed the problem. Regardless because this is an older and off the shelf computer upgrading it will be difficult due to the fact that celeron's don't have the same socket type as newer processors. If it is a motherboard issue then you will need a new motherboard and a new processor for that motherboard. Essentially the easiest and most cost effective thing would be to get a new computer.
Feb 28, 2011 | HP Compaq Presario SR2011WM PC Desktop
Compaq presario sr2011wm desktop push power on button and the computer won't come on. tried unplugin powercord and waiting for ten seconds and still didn't come on and I've tried removin and restalling...
the psu is bad.
the test is easy , one jumper wire prove PSU bad.
if its fan is dead, (and all fans )
jump pins 16 to 17 (power on pin jumped to ground 17)
connector pulled, turns it on.
see here. and why
http://www.pcdied.com/power.html#Jumper
Sep 16, 2017 | HP Compaq Presario SR2011WM PC Desktop
Downloaded the driver and still cannot connect to
Hi. Try these simple steps:
Go to device manager
Right-click the realtek LAN and select uninstall
Restart your machine
Download and save this file in your flash drive:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-42532-1&lc=en&dlc=en&cc=us&os=228&product=3292424&sw_lang=
Install it in your Desktop
Open Internet explorer and see if you're able to connect
Good Luck!
^_^
Jun 06, 2010 | HP Compaq Presario SR2011WM PC Desktop
Replaced power supply and still does not start on sr2011wm
try to reset your bios.. remove your battery in the mother board and place it back
Jan 16, 2010 | HP Compaq Presario SR2011WM PC Desktop
On my friends Compaq: running xp media ctr. He
If he has a product key for the computer he can borrow an XP disc from a friend and reload it using his keyand it should be fine.
He should then create a restore disc and keep it.
Jan 05, 2010 | HP Compaq Presario SR2011WM PC Desktop
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Pressler, 65nm)
    • Pentium D 800 series Dual Core (Smithfield, 90nm)
    • Pentium 4 601 series (Cedar Mill, 65nm)
    • Pentium 4 600 series (Prescott, 90nm)
    • Pentium 4 500 and 501 series (Prescott, 90nm)
    • Celeron D series (Prescott, 90nm)
Hope it helped.
Nov 19, 2009 | HP Compaq Presario SR2011WM PC Desktop
Fan runs but no boot
your motherboard is the problem. you should get it checked out at a local computer store.
Aug 22, 2009 | HP Compaq Presario SR2011WM PC Desktop
Computer hangs during pc recovery process
you may need to swap the disc from one cd-rom to another.
Mar 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
See all Compaq (A7486A) Questions
Compaq (A7486A) Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
