Question about Toshiba Satellite A100-S8111TD Notebook
I have no sound in my laptop.and i don't now how i go to the bios setup
Sound
  • Mike Gagnon
    Mike Gagnon May 11, 2010
    Could you post problem better so I may see your problem?
Dell latitude d510 with no sound
Have you check in BIOS setup ?.. may be audio setting "disable"..try set to enable..
Dec 30, 2013 | Computers & Internet
My asus g73jh has no sound and all usb port not recognized. I reinstalled everything(win 7, bios update, driver,...) but still don't work
For the sound, try going to
Control Panel > Sound > Playback
or
Control Panel > Hardware and Sound > Manage Playback Devices
and right-click speakers and select "Set as Default Device"
Jun 18, 2012 | ASUS G73JHA1 Notebook
Computer have not sound. sound driver is not instoled
The onboard sound must be turned on in your bios Setup pages.
Aug 08, 2010 | Computers & Internet
The voice and sound on my laptop is not working dell d10
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the laptop on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most system's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
The on-board sound setting in the BIOS should be Enabled. To enter the BIOS, turn on the laptop and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If that doesnt work and you have an installation CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Feb 20, 2010 | Shuttle D10 - SFF - no CPU - RAM 0 MB - no...
The sound is too low
enable on board audio in bios setup
Don
Jul 11, 2009 | Computers & Internet
Finding a sound card for my gateway laptop to be able to record audio
A sound card is a piece of hardware, and if not included with your laptop, you need to buy one and install it.
It is possible that you have a sound card, but it might be disabled in the BIOS. You would need to restart your computer, and enter the BIOS setup program to check if you have a sound card that is disabled.
You can go to gateway website and their website will tell you which hardware is installed
Apr 24, 2009 | Computers & Internet
FROZEN IN LOGGING OFF MODE
go to control panel , sounds - under windows sign off choose no sound for this event.
If all else fails depress the power button until it powers off (longer than 5-10 seconds) or remove battery. after restart go into bios setup and reset default values and re-start your computer
Don
Jan 18, 2009 | Toshiba Satellite Pro A210-EZ2202X...
My laptop toshiba satellite m105-s3041 cant running well because not sound device or soundcard detectif. can u tell me why?
first, you go in the BIOS setup..check if the soundcard is disable or not...if disable try to enable and boot to the windows..if its already enable but still not working, check the sound card driver at www.toshiba.com and download driver for sound of your laptop....
Dec 18, 2008 | Toshiba Satellite M105-S3041Notebook
Please help me
Download, install, and run Everest Home Edition on this machine. (Clean FreeWare) Once it's finished loading and running, look under Multimedia, or, under Multimedia, PCI / PnP Audio. This will tell you what sound devices you have available on your system.
http://www.findmysoft.com/drivers/Acer-Aspire-5100-3-05-bios-driver.html
http://support.microsoft.com/kb/948481
Hope this may help;
Regards,
VOTIT
DON’T FORGET TO RATE:
Aug 10, 2008 | Dell Latitude D600 Notebook
Acer aspire 5050 - beeping laptop
i think your bios setup changed.
press key with which u enter bios setup.
then load default settings and save it
then restart pc.
Mar 21, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
