Question about Magic Chef CTB1722 Top Freezer Refrigerator
Refrigerator not cooling at all but compressor is running
I have a Magic Chef Over/Under Refrigerator that has been in storage for a while. When we plugged it back up, it wouldn't cool at all. I've checked everything I know to check. Compressor starts up fine. Condenser fan is good. The only odd thing I noticed is that the evaporator fan only runs when I turn the defrost timer to the defrost mode. The compressor quits and the evaporator fan comes right on. When I keep turning, the evaporator fan turns off and the compressor comes right back on. Should that not be the reverse? In making my way to the evaporator fan I took the bottom freezer panel out. I've noticed that the evaporator tubing/coils aren't the slightest bit cold. Should they be cold without the fan going or does the fan cause them to become cold somehow? I appreciate any help. I'm at a dead end on this one. By the way, my actual model number(in case it matters) is RB23G -3PW but that one wasn't listed.
Tere is n o gas incompresor
Posted on Jul 26, 2007
  • 64 Answers
They'd at least be cool to the touch regardless i think. This seems dead, I had one that would clink alot. Try unplugging it, moving it away from the walla a bit and plugging it in with the freezer all the way to a 0 setting then work it up to full slowly hope this helps!
SOURCE:
MCBR240s Magic Chef Fridge does not cool. Compressor gets very hot when plugged in, but no cooling, it also makes clicking noises
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Magic Chef MCBR440 Compact Refrigerator
I have a magic chef mcbr170W - it will not get cool - any suggestions?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 04, 2011 | Magic Chef Refrigerators
Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
709oy
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
Magic chef side by side not keeping cool around 50 deg.and freezer not makeing ice cubs and not realy cooling also
heatman101
arha46w
Jul 01, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
My Magic Chef refrigerator model CTB1722GR is blowing nothing but warm air. Compressor failure???
Good day,
Four possibilities.
1. The condenser cooling fan motor located on the bottom back of the machine between the compressor, and box condenser has failed, and needs replaced. It should be running if the fan in the freezer is running.
2. Loss of refrigerant or a restriction in the system. Testing limited to a qualified tech only.
3. The combo relay overload mounted on the compressor( under a cover) has failed. Most appliance parts houses will be glad to test them for you.
4. Locked compressor. Tech only solution.
PS. If the machine is less than 5 years old, the compressor is under warranty. Contact your selling dealer.
Thank you for using FixYa
Dec 27, 2009 | Magic Chef Refrigerators
My magic chef refridgeator/freezer is no longer
You compressor is clicking trying to start. The insides of the compressor have siezed up meaning that they will not let the motor run and turn them. The motor trying to run and not being able to makes it very hot. Unplug it and let it cool down over night, it may go for a while then, but it is probably terminal. Getting the compressor replaced will cost almost as much as new. Is it possibly under warranty?
Nov 12, 2009 | Refrigerators
Magic Chef Refrigerator has stopped cooling adequately.
Check the compressor and the Relay, the relay is located on the compressor itself. you should have full voltage to both of those. If oyu have voltage to the relay and not the compressor then the relay is bad. If you have power to both and the compressor will not kick on then you have a bad compressor and it is best to just replace the fridge
Apr 26, 2009 | Magic Chef MCBR170 Compact Refrigerator
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef CTB1722 Top Freezer Refrigerator Logo
278 people viewed this question
Top Magic Chef Refrigerators Experts
vince
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
