New split system blows only hot air
I just instaled new kevinator splitsystem internal fan and external fan on the compresor come on but only hot air blows not cooling atall inverter split type compresor does not come on
  • luke bussenschutt May 11, 2010
    check interconnecting wiring between the indoor and the outdooor unit, if that is ok you could have a faulty inverter board.
  • 400 Answers
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Posted on Mar 05, 2009
2005 XG350 ac blows hot air not cold dealer installed new compresor, and belts blows 70 degree air at dash grills
A system will only drop temp about 20 degrees from outside temp. I would have then recheck the Freon level again. To much is as bad as to little when it come to Freon. Also the oil level can be to high causing the same thing. When they changed the compressor they should have also replaced the dryer and the orfice tube/screen. If that wasn't don't you could have a obstruction in line.
Aug 24, 2014 | Cars & Trucks
Ptac153b50am not blowing hot air
Have an identical unit. Replaced the heater core which has built in limit switches. Didn't fix. Finally fixed it by replacing the heater relays (small black boxes soldered into the circuit board). Can purchase at Digi-Key online for $4 apiece or buy a new circuit board for about $100.
Jan 04, 2013 | Amana PTC153B50AM Split System Air...
Does not heat or cool
Hi, If the outdoor unit is running, make sure the fan is on also. If the system is new and has just been installed, it sounds like you may have a freon leak and have lost all its freon. Turn it on cool and let it run for a few minutes. Go outside and grab hold of the larger copper line coming out of the unit. It should be nice and cold and sweating. If not, and the fan and compressor are up and running, you have a leak and lost its charge. Check this and get back to me and let me know what you have found. We can go from there.
Shastalaker7
PS, When these installers put these units in, they sometimes get in a hurry and there welds are not very good and will leak over time, just to let you know.
Jan 26, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Blowing hot air
check the contactor that powers the compressor for 240 volts a.c. and make sure you have 24 volts a.c. to energize the contactor from the thermostat inside the building,you can check both these voltages from the contactor
Jan 17, 2010 | LG LSC091PMA Split System Air Conditioner
My dur therm air conditioner fan turns on but compresor does not
it could be the (LP) low pressure switch which would shut the unit down
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Nov 30, 2008 | Frigidaire FRT18G4A Top Freezer...
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
