Question about PDP Systems Dethatcher Attachment for Honda 25cc 4-cycle Mini Tiller
Dethatcher pins on my accessory for the honda FG 110 are broken
Is there any place where I can get more of the dethatcher pins for that attachment? Honda only sells the entire unit. I accidently ran the unit against the side walk. The main unit is the Honda FG 110 mini rototiller.
  • 267 Answers
Posted on Feb 08, 2009
What is torque for a fg wheel nut ?
Ford Falcon Fg Xr6
130 to 140 nm
110 ft/lb for standard nuts,
90-100 ft/lb for lock nuts
most wheel nut torques for fords and commys are that
any more may break an old stud
fg falcon forum
Nov 10, 2016 | Cars & Trucks
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
Sorry they do not make a dethatcher for them not enough power .
Jun 27, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Side panel of the seat has come loose
Panels are held in place by plastic "pins" (to use your words) that are held in place by the shape of the part it is being pushed into.
Either the pin itself is broken, the part holding this plastic pin is broken, or the other piece being pushed into is broken or cracked such that it can't hold the pin in place.
Inspect both the side panel and the part it connects to. Replacement pins can be purchased from an automotive store or a salvage yard. If the receiving end is broken, you may be able to repair with glue or other type of bonding material.
Feb 09, 2014 | Vehicle Parts & Accessories
Where to connect the throttle cable on a GX 31 honda motor FG 100 tiller
I look up honda engines at : they have the best access to detailed information. If you can identify the carb butterfly, any cable should attach to the butterfly control. I see a Honda GX100, but not a GX31.
Oct 09, 2012 | Honda Horizontal OHV Engine 340cc, GX...
How to I change and attsch the thatcher and the aerator
On the link below it will tell you how to change the attachments.
Good Luck and please accept the answer.
Sep 25, 2010 | Mantis Aerator Dethatcher Combo
Year Yamaha fg 110 serial # 708896 was made?
The manufacture year for Yamaha fg 110 is (1969)
Sep 26, 2009 | Yamaha Music
Gas tank door opener in Honda Odyssey 1997
If the lever itself is broken remove it it will have a cable attached to it. unhook the lever from the cable and pull the inner cord of the cable with plyer's or simular. If the lever is'nt broken it may be stressed so follow the same process. As to removing check arround the lever for screws if no screws the lever pivets on a pin gently tap out the pin with a small punch and hammer if you havent got a suitable punch then file or cut the point of a small nail.
Aug 09, 2009 | 1997 Honda Odyssey
PDP Systems Dethatcher Attachment for Honda 25cc 4-cycle Mini Tiller Logo
681 people viewed this question
Top PDP Systems Garden Experts
Dennis Key
Dennis Key
john h
Are you a PDP Systems Garden Expert? Answer questions, earn points and help others
