Question about IBM Lexmark Z715 InkJet Printer
How do I keep my ink cartridges from drying out ?
I may not use the printer for a couple of weeks and then do a lot of printing. In the mean time the print cartridges dry out.
It would normally dry out if not used for a long time. Take it out and construct a cardboard casing around each cartridge so that the print head is not touching any surface. seal it with a plastic bag or container and store in a cool dry place. when you are ready to use them press the print head on a piece of tissue paper to prime the ink out. the ink should make a mark on the tissue's surface, then it s ready to be used.
Posted on Jan 29, 2009
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
Tip
What to do if you are not printing for a long time.
Do not keep the cartridges inside the printer for a long time, if you are not prinitng for a period of time. There are chances that the ink may dried off and that may lead to poor print quality. Keep the cartridges in an air tight container. Insert the cartridge into the printer once in a week and just print a sample page. Do the same process regularly.
on Apr 15, 2010 | Office Equipment & Supplies
Tip
Little Known Facts About Extending The Life of Printer Ink Cartridges.
Did you know that a perfectly good ink cartridge can dry out enough in just two weeks to be no good ever again. Not that all of the ink drys out, just that the ink closest to the working exit drys, clogging the exit holes and preventing the liquid ink from exiting. Often the printer indicates that the cartridge is still close to full but that color will not print out. I recently had this happen with an expensive jumbo black cartridge. After researching this and speaking with two printer technicians, my worst fear was confirmed. My almost new $35.00 ink cartridge was no good. And there is no way to fix it.
Knowing that these cartridges dry out pretty quickly, do not purchase a jumbo cartridge unless you do a lot of printing on a regular basis. The regular cartridges are good for about 200 copies and the jumbo cartridges are good for about 650 copies. If you know you aren't going to use your printer for the next couple of weeks or longer, remove the cartridges and store them.
Follow these steps for the best results:
1. Moisten a cotton ball with a small amount of tap water and carefully clean the residual ink from the working surcface of the cartridge.
2. Use a piece of plastic wrap to cover the working surface of the cartridge.
3. Store the cartridges in a ziplock bag trying to get out as much air as possible. This will prevent the ink from drying and clogging the holes.
I know this seems like a bit of work, but with the cost of these cartridges, it is time well spent. Happy printing everyone!
on Mar 19, 2010 | Office Equipment & Supplies
Canon Pixma MG3150 not printing or lifting paper from the input tray?
Please check the cartridges.Re install the cartridges properly and try.
if ink is dried refill the ink.some times will happen to new printers also.if waranty is there cary to nearest service point.
Nov 07, 2013 | Canon Pixma MG3150 All-In-One Color...
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
Replaced black ink but still says no black ink
please ignore that message and keep on printing, and if your printer does not print then dont use your printer for several days and keep your cartridge out of your printer for around a week and a half,but keep it safely so that its printing head is not damaged. and run the printer without cartridge for several times . this will help the printer in identifying that there is no cartridge in the printer and after that keep the cartridge safely out of printer and run after 10 days again by putting back your cartridge
that may help you, and after this procedure the problem which you can face is of dry ink .so apply some isopropyle alcohol on your cartridge print head (don't rub it)only put some drops of it on head and let the print head absorb it, this may be done when your cartridge s identified by your printer after 10 days and the error of low ink is gone.
Best of luck
Take care and please vote for me
Sachin
Jan 25, 2011 | HP OfficeJet Pro k550 Printer
Epson 440 won't print
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
Jan 06, 2009 | Epson Stylus Color 440 InkJet Printer
The print heads are clogged with dry ink.
Yup, thats the problem....
To keep them clean you need to almost use the printer weekly....or at least once per month min....
Try running the head cleaning utility....
You can run it as long as you have ink in your cartridges, maybe 5 times in a row....Wait about 10 minutes and try again....
With luck it will unclog itself....
Note: Your cartridge can also dry out (Yes the liquid evaporates), and leaves the pigment in the cartridge, which can further clog your machine....
As a last resort there are a few vendors on the internet where you can purchase head cleaning solution for epson cartridges....
Note; This problem is more common with printers that use pigment based ink as it tends to settle in the cartridge. Dye based ink has a shorter "Brilliance lifespan" but tends not to clog...
Feb 09, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
IBM Lexmark Z715 InkJet Printer Logo
204 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
