Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Fuel Oil Smell in House
Almost daily I can smell the fuel oil in the house. This usually happens when the stove is not firing. The fire stays lit. and the stove is heating OK.
  • Thomas Hawkins May 11, 2010
    Sir,
    What model heater do you have?
    Tom Hawkins
    hawkins111@gci.net
  • 137 Answers
With any internal combustion devise it needs oxygen to combust the fuel, I suspect that your house is sealed shut to keep out the cold.  I suggest that you raise a window slightly so as to cause a draft for the heater. Be sure that the raised window is not between people and the heater because the cold air will pass over them and they will get very chilled.
This is the same fix for smoking fireplaces.
Posted on Jan 29, 2009
Secondhand ,when I put heating on I can smell diesel fumes ,what could it be
Since there's very little information to go on, I'll guess...
Guessing it is a car or truck.
Guessing you have an exhaust leak under the hood.
Guessing the air intakes for heat are picking some of that up.
Oct 26, 2015 | Miscellaneous
Laser 72
Your manufacturer, Toyotomiusa, recommends that you tighten all the joints on the fuel line. Your owner's manual CLICK HERE contains detailed drawings showing the location of all parts, including the fuel injector. Your unit will need to be serviced by a qualified technician if you have tightened the connectors and still smell kerosene or find wet spots under your heater. It should not leak or smell of kerosene. If you're smelling kerosene, you should not operate the unit, because the leak may cause a fire.
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater:...
Smell fuel when idling
Were your plugs gaped correctly?
When you pulled the old plugs, were they very black or covered in oil?
If they were black, you have an oil leak. Check the area around the wires and see if there is any excessive oil buildup.
The fuel smell would be coming from the unburned fuel passing through your engine.
Did you have all the wires put back on one at a time? If not, you might have gotten the firing order wrong, or you have a bad coil pack.
Jan 08, 2014 | Chrysler Cars & Trucks
Fuel oil smell in the house
Fuel oil--- is a #2 oil & sometimes has kerosene in it also & is not like gasoline, that is combustible
Fairly safe,just smells strong
Nov 25, 2012 | Cars & Trucks
I have a ef falcon station wagon which I believe has a fuel punp problem. The reason I believe this is the case is because the other day as I was driving the car broke down. Like I had ran out of fuel. I...
Usually white smoke means there is water getting into the cylinders, indication usually of a head gasket failure. the smell of fuel could be that it is flooding due to compression and vaccum. Check your oil for water and your water for oil. Hope this helps.
Jun 09, 2011 | Ford E-Series Wagon Cars & Trucks
Getting gas smells and misfiring on a 2000 chevy venture. what might be the problem? was told not running on 2 of the 6 cylinders could that be the only problem? i am being told its something else
first off you have to fix the misfire problem before you can do anything else,as a misfire will cause a fuel smell because you have 2 cylinders acting like a raw fuel pump ,by the fuel entering the cylinder not burning a being pumped out unburned.so you have to find out why it is your six cylinder car is only running on 4 cylinders and repair the problem.then you can go from there if you have to,also you will have to change the oil as it will have fuel in the oil which thins out the oil to a point it does not do it`s job and could ignite in the oil pan causing other problems
Mar 04, 2011 | Chevrolet Venture Cars & Trucks
I have just lit a coal fire for the first time in the living room, all is OK ecept when I went into the bedroom (2 floors above) I could smell smoke quite badly Any advice?
The chimney needs to be 3 feet taller than the highest point of the house . If you are running the clothes dryer, bathroom vent fan, or exaust hood in kitchen it makes a vacum in the house that can draw smoke into the house down the chimmney . I think when you burn wood or coal in a house it is pretty hard not to be able to smell it. Our house and clothes do not smell like smoke any more since we stopped burning wood.
Feb 02, 2011 | Heating & Cooling
Smell of gas on oil stick engine light on and off 98 camaro
your fuel injections lines in intake and injectors and fuel pressure regulator. could be leaking.look under hood.on intake where fuel pressure regulator. is look for gas odor and gas leak.if you get a strong gas scent you need to fix it quick.you got a fire hazard.
Jun 05, 2009 | 1998 Chevrolet Camaro
Smell of oil throughout the house when the boiler is on
Other than the stench of fuel oil permeating every soft surface throughout the house, there are numerous health hazards associated with exposure to petrochemical vapors. Shut the unit off until you can get it repaired.
Mar 16, 2009 | ACCO Brands Water Heaters
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
811 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
