Question about Yamaha RX-V363 Receiver
LG-RH399H dvd recorder HDMI problem
I use timeshift and then save whatever part I like during the 6 hours of timeshifting. I usually turn off tv and leave but when i get back I find out that when I try to turn on the tv there is no signal from lg dvd recorder so i have to unplug and plug hdmi cable again to be able to get back reception.is it a problem with my lg dvd recorder or is it normal ?
tech48
  • 624 Answers
SOURCE: Yamaha RX-V663 Not Providing 1080 Signal
First let me say that you have stated your problem very well. I completely understand the issue you are having.
I have been repairing a/v systems since they started selling them.
By your description of your problem, it is obvious that you have isolated the problem to the Yamaha.
Despite what Yamaha tech support say's, it is their problem.
I have been dealing with tech support for a lot of different manufacters for many, many years. I repair under warranty over 20 different brands, but not Yamaha. I have repaired plenty of Yamaha receivers but none with this particular problem.
It is not uncommon to find tech support people who don't know as much as they should about their own product.
Since I don't have the instruction manual or a service manual forthis model I can only be of minimal help.
What you can do, if you have your instruction manual, check it over closely for this subject on how to change the settings for the HDMI. If you can not find this particular issue, it is possible that the Yamaha doesn't support 1080i. I would be surprised if it did not, but stranger things have happened.
Another thing you can do if you can still not find an answer to this problem is to take it in to an authorized Yamaha service center.
If you have recently purchased this Yamaha, it will be under warranty. They get at least 1 year. Tell them the problem you are having and if they do not know how to solve it right there on the spot, or give you an answer that satisfies you, leave it with them
to have it fixed. If they are an authorized service center they will have to fix it or get it replaced for you if it is under warranty. It may need a firmware upgrade to the digital board. If that is the problem, then they can do it for you.
Let me know if you need any more help.
Sorry I wasn't more help, but an authorized service center may be your best bet.
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: No Audio Coming Through On HDMI DTV/Cable INPUT
The HTR-6130 cannot decode HDMI audio. It can only act as an HDMI switch. To get the audio from the cable box to be output from the HTR-6130, you will need a separate audio connection (e.g. RCA cable).
Posted on Jan 02, 2009
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
  • 3 Answers
SOURCE: I have HDMI cable from TV to RX-V365. HDMI from
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
Posted on Jan 04, 2010
How do I record a programme/film on my Samsung smart TV without having to watch what I'm recording and also how do I record more than one thing on at the same time.
This is not possible, samsung tv do not have a recorder per say it is a timeshift function. So you can only record one channel at the same time. If you need this kind of thing try using TiVo or some service that your ISP provider offers.
Apr 01, 2015 | Samsung Televison & Video
I have a LG DVD Recorder, Model no. RH399H. When I turn it on it only goes as far as the greeting screen "HELLO" and nothing further. Could you please tell me what could be the problem
Sep 13, 2010 | LG Audio Players & Recorders
Samsung dvd sh897m - can not use the timeshift function -just get the no entry sign - no timeshift menu is displayed
just a question of connecting the aerial cable from the dvd player direct to the sky box - now working.
Jan 01, 2010 | Televison & Video
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
LG RH7796W DVD/HDD Recorder
The problem has fixed itself, thank you
Feb 26, 2008 | LG RH177 DVD Recorder/HDD Recorder
Timer programming problem
Check to see that you have not changed the default choice for input on power up of the box the "timeshift default device". If you have it set to front or rear CVBS or S-video input, it may ignore the channel choice you make when setting up the recording.
tom
Feb 13, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Timeshift
-- If you do have a legal version...
First check and see if your "Caps Lock" is on?
Be absolutely sure that you are entering the registration code EXACTLY as printed, Use CAPITAL LETTERS as printed, and lower case letters as required.
If it still won't work....
Call TimeShift and explain the situation, have a magnifying glass handy to read the tiny engraved lettering in the center of the CD disk.
If you have some kind of sales receipt, or other "Proof of Purchase" have it handy too.
They can create a new product key for you.
This method will only work if you have a legal copy of the program.
Dec 04, 2007 | Microsoft Office Standard for PC
Yamaha RX-V363 Receiver Logo
486 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
