Question about Sony PlayStation 2 (PS2) Console
Have a Konka TV but ps2 doesnt play through it.
Tried plugging the red,white,and yellow connectors from the play station into different audio connections on the TV. Plays through the TV black and white. Goes ok on the older TV's?
  • 118 Answers
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Posted on Jan 30, 2009
When i turn on my ps2(slim) i cant see or hear eny on the TV way is the happing plz help me
Check your A/V cable connections. They are the Yellow (Video), White (Left audio), and Red (Right audio)wires coming from the back of your PS2 to the connectors on your TV. Be sure they are plugged in and they have a tight connection. Also, be sure they are plugged into the appropriate jacks. They jacks are usually color-coded to match the connector type. Then check to make sure the plug that connects to the back of your console is in the correct port and is snug as well. A loose connection anywhere will prevent anything from coming up, the PS2 was infamous for that.
Aside from issues with A/V, be sure your TV is on and tuned to the correct source. If your PS2 plugs into an RF switch which plugs into the coaxial (cable) port on the back of your TV, the channel should match what the RF adapter is set to before turning on the console. If the PS2 is plugged into your TV through the A/V cables (The yellow, white, and red connectors we discussed earlier), make sure your TV is set to the proper source. The source channels could either be labeled "Video 1," "Video 2," or "Video 3," depending on your configuration. Also, the source could also be labeled "Game."
If none of the two solutions above work, then it appears your PS2 has bitten the dust. Best thing to do is give it a nice tombstone with a beautiful eulogy to make even the most battle-hardened tough guys cry like a baby
May 04, 2011 | Sony PlayStation 2 (PS2) Console
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
Feb 06, 2011 | Computers & Internet
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I am trying to connect a play station 2 to our Akira TV. I plug in the yellow Playstation plug to the green socker and then connect the sound. I don't get any colour in the picture. What could be the...
You shouldn't connect the yellow into the green socket. The Red/Green/White sockets are for HD and therefore won't work correctly with your usually RCA cables. Your TV should have Red/Yellow/White RCA input somewhere. If not you may have to use a VCR or DVD player to connect your system to your TV.
Dec 18, 2009 | Sony PlayStation 2 (PS2) Console
Have no colour coded holes in my lcd t.v to connect my play station 2 and have no picture at all just normal chanles and the power indicator light is on ?????????????
Check for outlets marked video in, audio in l,r on the back, side or front of your tv. The yellow ps2 plug would go into the video in, red & white would plug into the l,r audio in. You would then need to set the tv to video 1 setting in order to play. Hope this helps.
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Dec 30, 2008 | Durabrand DWT1304 13" TV
PS2 hook-up
I would suggest to feed video from another source such as DVD or VCR to the same input, if the video is visible from other sources on your TV; that means the video cable from your PS2 is defective. If you did not see any video from the DVD or VCR nor the PS2, it means that there maybe a loose connection inside the TV on the video input.
Hope this helps.
Jan 03, 2008 | Sanyo DS31590 31" TV
Sound but no video
Run your yellow cable from the DVD player directly to the TV in the port connected to the red/white cables. If this is already done or doesnt, work, let me know
Jul 26, 2007 | Koss C928 System
Sony PlayStation 2 (PS2) Console Logo
305 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
