Question about Panasonic DMR-ES25 DVD Recorder
Remote control won't work for DVD Recorder
Went to use remote last night and all I got was DVD1 showing on the DVD recorder when enevr I pressed a button. Have changed the batteries, unlpugged the machine for a period of time, tried the child lock theory and all the things in the handbook but cannot move past DVD1 error when any button is pressed on the remote control. My local shop is closed due to the floods-can anyone help me with the DVD recorder problem? Many Thanks
    Novelist:
    Scholar:
  • 84 Answers
Hi abrooks...Clicking on the following URL will take you directly to the Acceptance Page that will allow you to download the proper update applicable to your Unit and Issue. Applying this update to your player will provide your resolution....good luck my friend http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloadsTermsConditions?storeId=15001&fileName=DMR-ES25/DMR-ES25.EXE The following are details of the file that you will be downloading; Version: IR-01 Last Updated: 5/2/2006 Description: This version restores IR Remote operation if the unit has stopped responding. After this update has been installed, please be sure to disconnect the unit from AC power for a minimum of 30 seconds.
Posted on Aug 03, 2007
SOURCE:
My Remote doesn't work, replaced the battery's works for the TV, but not the recorder, is there a default reset on the recorder? because I've changed the dvd3 to dvd1 so I'm not getting anything to display...
make sure remote and dvd select the same setting DVD1 on dvd recorder, so DVD1 on the remote, ther is some writing in the manual how to change the remote from dvd 1 to 2 and 3
Dec 31, 2010 | Sony RDR-HX825 DVD Recorder/HDD Recorder
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Jul 24, 2009 | Panasonic DMR-ES10 DVD Recorder
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Trouble with remote
This happened to me twice before, I forgot the solution but it's in the owners manual, if you dont have it, go view it on pansonic's site.
Oct 14, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-ES25 DVD Recorder Logo
142 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
