Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
My cozy heater was hit when another appliance fell on it and impacted it. Apparently some safety mechanism shut it off now I can't turn it back on. Thanx
  • 3 Answers
Most heaters have safety switches on them in case they turn over. Ohm the wires and make sure the switch is closed. Most of them are inside and on the side of the heaters. They have 2 wires on them.
Posted on Jan 30, 2009
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Dec 06, 2017 | Cozy Heating & Cooling
How to open Cozy gas heater
See if you can blow out the dust with compressed air. Make sure you get ALL the dust out...that dust could ignite & start a fire!!!! If you can't, don't use the heater. Be sure to re-assemble per original design; or if you can't, don't use the heater!
SAFETY FIRST!!!!!!!
Nov 14, 2013 | Cozy Enclosed Front Console Heater 70,000...
The Cozy Console Pilot flame has been off less than a hour today 07-07 2010 can we wait till the spring time to put back on or call the Gas- company?
Hi, if you are saying that its off now and is it OK to leave it off until spring, yes it is. If you want it to stay off, you can also shut the gas off at the flex line that supplies gas to the unit. Just turn the small handle to the off position, this is just for added safety.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
Need the safety switch between the gas valve and thermocouple for a cozy heater VC202A
Locate your part number here http://www.cozyheaters.com/pdfs/products/vcvcrR.pdf
Then you can order from any Cozy Dealer. You can fin that from their website or by calling them. It looks like a $12.00 part.
Mar 18, 2010 | Cozy Heating & Cooling
Cozy hi-efficent wall furnace HEDV403
what you are doing is reseting the heater when you unplug it there should be a overheatswitch that is cutting in and shutting it down
Jan 11, 2009 | Cozy (W352E) Heater
The heater will not ignite properly
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
Cozy heater
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Nov 08, 2008 | Cozy Enclosed Front Console Heater 70,000...
Pilot Light Goes Out
The VC701 has a safety switch located on the back of he heater that may be tripping after the call for heat is satisfied. Check that there is a good draft by testing with a match. Make sure the flame is drawn toward the vent system when the unit is off and cooling down. Check it at the draft diverter located below where the vent pipe is attached. It is a box with an open bottom. If the draft is not pulling air toward the vent system, the heat from the cooling heater will trigger the safety switch and shut off the pilot. You may have to raise the vent pipe to establish a draft.
Nov 08, 2006 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
