Question about Motorola Mobility RAZR V3i Cellular Phone
Phone does not power up
My phone no longer powers up, it was not in use for a few months, 4 or 5 approximately, and now when plugged in and charging, it says...
BOOTLOADER USB INIT
Anyone have any ideas or a solution to this problem?
  • 139 Answers
There is a pin size hole in ur cellphone
put a pin in that hole and reset ur cell phone
Posted on Jan 29, 2009
My battrey is not charging
1) is the power source active (some wall sockets have a switch to render power there inactive -Australia)
2) is the charger plugged into an active power strip or an active wall socket?
3) is the charger damaged?
4) how long has the cell phone been charging? If the battery was completely discharged, it may take a bit for it to show a screen of it charging.
5) if the battery will not accept a charge, it will have to be replaced. Lithium batteries retain longer life spans if you charge them when power level is down to about 20 percent, NOT when they are completely discharged.
6) Better write down the battery number and amps when you pull the battery and keep it with phone documentation.
Jun 12, 2017 | Cell Phones
I need my safelink phone activated but unsure what the activation is? Is it the serial #?? I've had it for a few months and can't use it,.
STEP 1: Open the box that your new SafeLink Wireless phone came in and remove the contents.
STEP 2: Unravel the power cord and insert it into your new cell phone, then plug it in. Wait for the phone to charge fully before activating it. This will take approximately one to two hours.
STEP 3: Locate the activation card that came inside your SafeLink box. Follow the instructions on the card to activate your phone line. If no activation card is present in your SafeLink box, your phone is already activated.
STEP 4: Power on your cell phone and make a test call to confirm that it is properly activated. If the call goes through, your line is now active and ready to use.
Nov 28, 2016 | Cell Phones
What is a SIM card? I need to activate my phone. I've had it for a few months and can't get it to work. Thanks
STEP 1 Open the box that your new SafeLink Wireless phone came in and remove the contents.
STEP 2 Unravel the power cord and insert it into your new cell phone, then plug it in. Wait for the phone to charge fully before activating it. This will take approximately one to two hours.
STEP 3 Locate the activation card that came inside your SafeLink box. Follow the instructions on the card to activate your phone line. If no activation card is present in your SafeLink box, your phone is already activated.
STEP 4 Power on your cell phone and make a test call to confirm that it is properly activated. If the call goes through, your line is now active and ready to use.
Nov 28, 2016 | Computers & Internet
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
Battery lufe is rubbish
How old is the phone/battery?
Most cells use LiPo batteries, which can be very tempermental. If they are fully discharged (used until they will not power item any longer) more than a few times, they can lose the ability to hold a charge. Also, check the phone's users manual for correct battery charge times, as many Li/Po batteries will show a full charge before they are actually fully charged, particularly for the first few charges. If your battery isn't holding a charge, the easy fix is to replace it, but if the phone/battery is less than 6-12 months old, I'd ask my cell provider to replace it as defective.
Hope this helps,
r
Sep 12, 2011 | Cell Phones
My nokia 5610 have no power at all but when i start to charge it has the indication of charging
This is because the only power the phone is receiving is from the power cord from the wall. When this problem occurs, it is because the battery in your phone is completely dead and not capable of receiving a charge (in other words the battery is fried). the solution would be a new battery. A tip on avoiding this problem in the future would be to only charge the phone to a "full charge" and then remove the charger. Avoid leaving it on charge all night while you sleep as this is the main cause of battery death. Also car chargers are another culprit, which is an un-known fact. a car charger uses a different kind of electricity which is stronger. If you have ever noticed that if it takes an hour to fully charge your phone when it is plugged into the wall, it may only take approximately 20 minutes to fully charge the phone in your car. So you if you must charge your phone in your car, charge it for no longer that 10 to 15 minutes at any one-time. good luck
Jan 20, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Samsung Freeform says ''no battery,'' why?
With your phone powered on, connect the charger to the phone. With your phone unlocked, press and hold the END key to power off your phone. The phone will now shutdown and then restart to the charging screen. As soon as you see the screen with the battery and the word "Charging..." under the battery, press and hold the END key to power on the phone. This must be done before the phone has a chance to display "No Battery".
May 21, 2010 | Cell Phones
Screen lights up when charging, but wont power on
Hi you have to hold the button down for few seconds if this dose not work leave to charge for longer,if you still have a problem your batt may not be holding charge
Jan 13, 2009 | LG KM500 Cellular Phone - Unlocked
Charging problem
how long have you had the phone? usually the longer you have the phone the more it uses battery. the same with cameras, laptops, etc... my guess would be that the battery is going bad. ive had a few phones for just a few months and the battery would barely hold a charge for a day. so try getting a new battery and hopefully that will solve the problem :). also make sure there arent any games or programs constantly running on the phone as that can also drain the power pretty quick. hope this helps!
Nov 04, 2008 | Lands Phones
Model28112 series cordless phone multi phones 4 total
This does not sound good. If you have one working phone and you have swapped batteries around and still the same single phone works.... you know it's not the base unit, charger stands, power supplies or batteries. You have eliminated everything but the phone itself. Unfortunatley these low end cordless phones cannot be expected to last. 6 months is pretty bad but I'm not surprized. These sell for $30 each new and I bet a replacement battery is $20.
Jul 01, 2007 | GE 28112 Trio Cordless Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
