42 degrees outside and air conditioner is blowing hot air!!
  • Anonymous Jan 29, 2009
    i have the same problem
  • Randy Hough
    Randy Hough May 11, 2010
    Wouldn't that be heat?
    Problem Solver:
  • 17 Answers
Turn the unit off at the main circuit breaker or isolating switch, to reset the unit it has tripped out on its high pressure safety. to stop this problem happening on 42 plus days hose down outdoor coil with water
Posted on Feb 10, 2009
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
House is not cooling but it is blowing 60 degree air from my vents right now it is 83 degrees outside and 81 degrees inside
check to see if there is a 20 degree split between supply and return air. If its less than 20 than it might be low on charge.
Jun 24, 2009 | Weather King 10AJA3601AH Air Conditioner
Window unit air conditioner kicks in only when its really hot out
I would consider replacing the t'stat if it does not seem to cycle at the desired temps. Also, the outside air allows fresh air to be introduced into the conditioned space but it will also effect, to a degree, the units ability to cool the conditioned space. Once you get the unit running, try it with the baffle on and closed and see which one you like. Remember, the outside air has and add humidity and can make it seem hotter than it really is in the room.
May 21, 2009 | Whirlpool Electronic Window Air...
When my unit is on the outside is not working the inside is blowing little hot air. What do I need to check? Its a Ruud Achievers Series
Set the thermostat four degrees lower then house temperature and fan to on. Go outside and see if fan is running. If not check circuit breaker.
Apr 26, 2009 | Ruud UBHC Air Conditioner
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
