Question about Whirlpool MH1150XMQ Microwave Oven
Microwave does not heat
Our microwave is around 3 years old. it still runs, but does not heat food. Is there a way to repair it??
  • 39 Answers
It could be any multitude of issues from a faulty magnetron,a bad high voltage diode, a door switch issue or a faulty circuit board. A magnetron for your model is ~ the $60 area. A Circuit board is ~ the $100.00 mark. If your a wiz at electronics I would say give it a go and try to repair it yourself. Otherwise I would say that a new microwave oven would be your best bet. A technician may charge you up to $250 for the work they will do, bringing you to around the same cost of a new microwave with a warranty. Hope this helps. P.S. If you are interested in buying the parts and fixing it yourself, may I recommend this site: http://www.repairclinic.com They are top notch and really helpful.
Posted on Jul 26, 2007
SOURCE:
My sharp carousel II microwave no longer heats food. Do I need to buy a new one?
The problem maybe the magnetron, or the inverter board if 7 years old or less, and possibly the keypad control board, by the time you add parts and labour cheaper to replace the microwave oven in the long run.
May 07, 2012 | Sharp Carousel R530EST Microwave Oven
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Oven won't heat food
Bad Magnetron. Unfortunately, and especially on high power microwaves, magnetrons do die. They'll probably run you between 100 and 300 dollars to replace. If you believe that your microwave is within warranty(not likely), contact the manufacturer for repairs. Otherwise, it may just be cheaper to purchase a new microwave.
Sorry that this answer doesn't produce a happy result, but it's an unfortunate fault of microwaves as a whole.
Apr 23, 2010 | Maytag MMV5186A Microwave Oven
Microwave runs, but food does not heat
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
No Heat.
Hi dadedulitl,
When you say "putting out no heat", I take that to mean it's not heating the food up. When a microwave suddenly stops heating food, but still appears to run, it's usually a defective/dead magnetron. Prices for replacement/repair will vary, you will need to find out what that service costs in your locality before having enough information to decide on repair or replacement.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer one's may have more power/less energy wastage, etc.
If it's ~ 3 years old, do you have an extended warranty?
If so, you might be able to use that (check the terms of the EW). Most standard warranties are for 1-2 years max, so unless you bought the EW, you're probably back to deciding between repair and replacement.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | Panasonic NN-P794SF Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
3 year old unit, oven works, microwave does not
hi,
You may need a new magnetron, contact sharp or the store you got it from; most microwaves have a 3-5 year warranty on the magnetron. If it's not in warranty, find a good appliance repairman, this is a difficult and dangerous repair job.
Apr 03, 2008 | Microwave Ovens
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
Whirlpool MH1150XMQ Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
