Question about Whirlpool MH1150XMQ Microwave Oven
Microwave runs but does not heat--is is repairable???
My microwave was working fine, and then the other night I was cooking rice and took it out at the end of 25 min. and the water was still cold, and the rice was uncooked...Since then, it runs, but does not heat....any ideas??
  • BONAPART Jan 03, 2008
    Got exactly the same problem with my "Promenade" Microwave grill: it runs fine but just won't heat or cook any food, regardless of the program choosen (defrost, cooking, ...)
    Would you say it is an easy fix or more kind of for the experience DIY guys?
  • 39 Answers
I replied to your other post as well: It could be any multitude of issues from a faulty magnetron,a bad high voltage diode, a door switch issue or a faulty circuit board. A magnetron for your model is ~ the $60 area. A Circuit board is ~ the $100.00 mark. If your a wiz at electronics I would say give it a go and try to repair it yourself. Otherwise I would say that a new microwave oven would be your best bet. A technician may charge you up to $250 for the work they will do, bringing you to around the same cost of a new microwave with a warranty. Hope this helps. P.S. If you are interested in buying the parts and fixing it yourself, may I recommend this site: They are top notch and really helpful.
Posted on Jul 26, 2007
  • mhouse19468 Jul 27, 2011
    My microwave was working fine until I set the timer and hit start by mistake and it ran empty for about15 minutes. Now it runs but will not heat up. Can running a microwave when empty actually kill it?
My microwave oven model IFB 17 PM - MEC1 runs but it does not heat anything. what can i do ? it is repair?
Posted on Nov 25, 2010
My swan sm2050 microwave is working but does not heat food is it worth getting it fixed or get a newone
Posted on Sep 23, 2012
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
I just bought a new rice cooker container for my family to cook rice. It saids use one cup of rice with 1 and a half of water and microwave for ten minutes. Then thought I use 3 cup of rice then must...
you do not need to triple the time when tripling the quantities, example: one baked potato = 8 min, 2 = 10 min,3= 12 min ....
sounds like a triple batch is a bit much for your microwave
so you may want to cut it in half
Feb 09, 2015 | Microwave Ovens
How to make rice
Cover with the lid and turn the heat down to its lowest setting. Leave it alone - once the lid is on, set the timer and go away! If you lift the lid and let the steam out you can slow down the cooking process, and rice should always be cooked as briefly as possible. Give white rice 15 minutes and brown rice 40 and use a timer - overcooking is what spoils rice. The best way to test if it is cooked is simply to bite a grain. Another way is to tilt the pan and, if liquid collects at the edge, it will need a couple more minutes' cooking.
May 31, 2014 | Emerson Microwave Ovens
I need the recipe for cooking rice in Crystalia Steamer/Rice Cooker
The general rule for cooking rice whether its in a rice cooker or a deep pan is to rinse the rice three times, put the same amount of water in the cooker (1 cup water to 1 cup rice). Turn on the cooker, let the rice cooker complete its cycle. Let the rice sit in the cooker for 10-15 minutes to steam. Serve.
You can vary the amount of water depending upon whether you want drier or moister rice. Enjoy.
May 30, 2011 | Microwave Ovens
Chefmate rice cooker instructions 10 cup
if you put a 10 cups of a rice rinse it first before you add a water , the measure of the water is equivalent of the cup of the,put 10 cups of water. then put it on the rice cooker, then press rice cooking, it is automatically turn to "keep warm" after it's getting boiled. wait for about 45mins of cooking.thanks.
May 07, 2011 | Microwave Ovens
Doesn't tell you how much water you use when say cooking a cup of rice or even half a cup,
Rice is boiled in water and so it is important that the rice is always soaked in water as it cooks. So depending on the type of rice the ratio might differ but have at least a level of water above the rice as it must never be left dry.
It depends on the vessel you cook but see that the water level does not overflow or go below level.
Feb 08, 2011 | Microwave Ovens
Lost my directions. What is the ratio of water to rice?
Generally 2:1 That is 2 cups of water for every cup of rice, use on High setting until rice is cooked to your liking.
Sep 29, 2010 | Microwave Ovens
Not heating up
weve found its not worth repairing microwaves
Jun 29, 2010 | Daewoo KOC-925T Microwave Oven
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
Whirlpool MH1150XMQ Microwave Oven Logo
2,418 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
