Question about Microsoft Windows Vista Ultimate Edition
.MSI not found when modifying exe from control panel
I had installed a product over a network. But from Control Panel when I try to modify the installation, message is displayed that the specified msi file not found even though the network is proper and msi file is present in the specified location??
OS is Windows Vista.
This problem happens only on Vista but on XP it works fine.
  • 156 Answers
Hi Vijay,
This might be an authentication problem, because added security in vista, please make sure both the systems are authorized to communicate to eachother and those files/folder have the sharing permissions. Alternatively copy that .msi to your systems/system32 folder
Hope It will work
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Posted on Jan 31, 2009
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
When i try to connect to my wireless network it ask for device ownership password. What does that mean
Hi britnatale,
If you go to Control Panel, select "Remove/Change" on the Intel wireless, then select "Modify" and "Next" you'll then have access to the installed settings. From here, uninstall/unselect "Single Sing On" and WiFi Protection. These will turn off the prompt.
Hope it works for you.
Apr 14, 2011 | Dell Computers & Internet
I am not able to install Corel Draw X5, after entering the serial key, it seems to install for about 45 mins and then ends up with """Your system has not been modified. To complete...
You may have a corrupted install. Check the control panel to see if Corel Draw installed. You can use the "uninstall software" from the control panel. then once uninstalled, try re-installing. Before doing all this I would reboot your computer.
Nov 04, 2017 | Corel DRAW Graphics Suite X5
Give me unit setup in nero 9
Here is something I was workining hard to solve: how to install any nero 9 app for example "Nero Burning rom" or "Nero Stsrtsmart" from one of the seperate .msi installers without setupx.exe. These installers are found when you extract the full downloaded packege of nero 9. In the folder you find folders named "unit_app_4", "unit_app_5" and so on.
Inside the unit_app folders you find cab files and an .msi installer. If you try to execute the .msi you recieve an error stating this program can only be started from "setupx.exe".
This is most distubing since what would seem to be the only option is to go through nero's set up process which is time consuming and annoying.
However I have discovered a way to choose the applications I like for example Nero burning rom which is the files in "unit_app_4" and install any one of these apps directly from the .msi installer.
To do this you will need an .msi windows installer editor. The one I use is "ORCA" which is available from microsoft and comes with the windows installer sdk.
The first thing to do is edit the .msi. The .msi in the folder to burning rom is labled "unit.msi" as are all the .msi installers for each app. Open orca. Drag and drop "unit.msi" onto orca.
On the left hand tables select "custom action'. On the right hand window under "action" select "CA_BeforeDeferredFinalizexxInstall". Right click on this and then delete it.
gif.gif Capture.JPG (54.59K)
Now find in the left hand "table" "launch condition". Right click on it and select "drop table".
gif.gif Cape.JPG (47.21K)
Save the changes and exit orca.
You should now be able to install the application with the modified installer be clicking on it.
After running the install you should find folders and files in "program files" and "program files\common files" but there will be no shortcuts.
We are not finished.
If you go to the folder that contains "nero.exe" don't even try it becouse it won't work.
Nero applications will only work with a serial key and a crucial file which must be registerd.
You need this file: "AdvrCntr4.dll". In ordern to get this file you will have to run the full packege installer or setupx.exe. When you get to the first welcome to nero page go to your temp folder and you will find a folder named "nro.tmp". Open this folder select "AdvrCntr4.dll" and move it to "program files\common files".
Open a commaned prompt. Change the directory to "program files\common files"(CD %systemdrive%\program files\common files)
Type "regsvr32 AdvrCntr4.dll"
It will confirm that the file is registered.
Now you need your serial.
Open a command. Type REG ADD HKLM\SOFTWARE\Nero\Shared\NL9 /v Serial9_1223131541 /d 1111-2222-3333-4444-5555-6666-7777-8888
Substitute these intergers with your key.
You may need the product id which is under the same key. The easiest way to enter it along with the serial is to install nero with the normal installer or setupx.exe go through the process and then export the key containing the product id and serial from registry editor.
(Be carful not to use the nero product id from vista on xp becouse they are different.)
--This edit is for people who modified their .msi but still can not launch it directly. This behavior only occurs if the .msi you edited has bean used previously.--
The reason for this is the .msi was executed before it was modified and the data base located in c:\windows\installer
is still refering to the previosly executed unmodified .msi.
To create a new data base find the .msi in the c:\windows\installer folder and delete it but thats hard to find so just move the installer folder somewhere outside of c:\windows, create a new folder in c:\windows named installer and execute the modified .msi which will create a new data base then move the installer folder you moved out of c:\windows back to c:\windows. The .msi should now execute directly.
Jul 19, 2010 | Ahead Software Nero 6.6 (600901) for PC
"a physical wifi adapter is not installed"
It could be better if u will run update on the device itself. Right click on my computer and select manage finally on computer icon or hardware to view the faulty device right click on the device and update or uninstall and reinstall.
Jul 11, 2010 | Dell Ethernet Card Network Adapter
Can't get installation disk for HPF4440 to load. Have Windows XP. Getting Error #1321. The installer has insufficient privileges to modify the file. Tried suggestions on HP website and haven't worked.
You are getting a Windows XP error.
The error means that the system thinks that your user account does not have the Rights to install your printer. Check Control Panel - User Accounts to be certain that your account is not a Limited account but has administrative rights.
Also, try right clicking the install.exe file on the printers CD and select "run as administrator".
Hope this helps.
Sep 18, 2009 | Office Equipment & Supplies
Device password????
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Dec 15, 2008 | Linksys WRT160N Wireless Router
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Microsoft Windows Vista Ultimate Edition Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
