Question about Radica U B Funkeys Green Fallout Computer
Re-setting a TCM Funk-Thermometer after battery change
I have a TCM Funk Thermometer, given to me as a gift 12-13 years ago. Each time I change the batteries, I battle to reset the the main unit as the manual I received with it is written in German. Is it at all possible to get some manual information for my model TCM Art 97001 written in English. Changing the batteries every now and then is the only maintenance it requires. A really excellent unit I would recommend to anyone. I look forward to a positive response.
Kind Regards
Dave Cobbold
I gave my Dad the same unit as a gift, just finished translating the relevant sections of the German manual for him. I can't post it here because it exceeds the maximum length, e-mail me at david [dot] moss [at] kit [dot] edu if you'd like a copy.
Posted on Feb 13, 2010
I put a 2006 mercury motor and transmission in a 2003 crown Vic rite it runs good but, it change 1 gear and after that my speed thermometer jumps from 50 to 130 and makes my car shut down
no idea what a speed thermometer is and what it does in the vehicle
all well and good with what you have done but the ECM for each vehicle will be different and so will be the TCM
the change is not just mechanical but will require a lot of electronic changes as there are too many years development between the transmissions
Jun 01, 2016 | Mercury Cars & Trucks
Was given a drill as a gift about 3yrs ago, tryed it for the first time recently. problem the charger doesn't charge the battery, had the charger checked and it is only putting out about 4b volts. How can...
After 3 years you probably can't get any kind of warranty support but you may be able to repair the charger or buy a universal one. www.centurytool.net sells parts for battery chargers....if you know where the drill was purchased, like sears, you may be able to take it there and they can either send it in for repairs or point you in the right directions. Most cordless drill batteries will go bad if they are not charged regularly so you may have to replace them also. Good luck!
Nov 29, 2009 | McCulloch Drills
I was given a george Foreman Lean Grill machine with a Contact Roasting Machine both in the one box as a gift about a year ago. when I opened it I noticed one of the machines had been used. someone, had...
when speaking to a friend about the missing user manual, she mentioned another friend who she thought had the same grill as I have. When further enquiries made,we found this person did have one and is sending me a copy of the manual. . I still have not solved the meat thermometer problem., but I am sure I will be able to buy something suitable , somewhere
Nov 17, 2009 | George Foreman GR30 Indoor Grill
Day light Savings time problem
Hi ... I have the same problem ... I found this link but I haven't tried it out yet ...
http://www.emersonradio.com/dst_g2.htm
Oct 27, 2008 | Emerson Smartset Clock Radio
Sony KP-61V85 background to HDTV Compatable Yes or No??
This TV is about 7 to 8 years old already and is not HDTV compatable.
Feb 13, 2008 | Sony KP-61V85 61" Rear Projection...
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Black-out
Sent it back under warranty- this has an internal fault.
Aug 06, 2007 | Kodak EasyShare C533 Digital Camera
Cyber-Shot DSC-S500
We had similiar problems with ours until we started making sure the camera was kept warm when it was shut off. For some reason, it and the batteries don't like the cold...we were able to extend the battery life if we kept it covered when we weren't using it.
May 10, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Radica U B Funkeys Green Fallout Computer Logo
1,650 people viewed this question
Top Radica Toys Experts
ray gallant
Are you a Radica Toy Expert? Answer questions, earn points and help others
