Question about Sony KDSR50XBR1 50" Projection HDTV
Change a lamp on sony bravia KDS60R2000
HoKDS60R2000w do i change a lamp on a sony bravia
    Problem Solver:
There is a door on the right hand side bottom
undo 1 screw pull out lamp
Posted on Jan 29, 2009
"My sony bravia kdf46e3000 wont always light the lamp when first turning tv on. I can see it sparks the lamp but the lamp only stays lit for about 3 seconds. The power light on the front stays green a
does the lamp fan stay on? you can see thru the back if the fan is running. If it is not running you need to replace it.
If it running you may need a new lamp driver/ballast part# 1-480-180-21 https://www.encompassparts.com/model/SONKDF46E3000/_/_/Sony/KDF46E3000/
then there is the possibility the new lamp is bad,, Sony's like Sony OEM lamps
Dec 20, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
What would be the cause? Sony Bravia standby light 3 blinks times any ideas?
try re-closing your lamp door. indicates possible lamp door/switch problem
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Sony Bravia SXRD KDS60R2000 won't turn on
May I know if there's a led light lit solid/blinking. If blinking, count how many times it will flash.
Oct 26, 2011 | Televison & Video
How to open the lamp cover for vpl aw15 sony bravia projector
Lamp cover is located at bottom of projector, loosen its screw and take off lamp cover. Process is also written in user manual page-56 with exploded views. Click Sony Support link to download user manual copy, check page-56 to have better idea.
Thanks.
Dec 14, 2010 | Sony BRAVIA VPL-AW15 LCD Projector
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
I have a Sony Bravia KDS-60A3000. I changed the lamp, plugged in the TV and it was working. Was trying to reset lamp indicator, power went off, red indicator light is blinking and cannot get TV to turn off...
I went to another tech site and saw a suggestion to unplug the TV for a couple hours and then plug back in to see if this helped, but they also indicated this could be a serious power problem. I was really concerned, but tried it and it worked! I think it was running some kind of diagnostics after the new lamp was placed. Back up and running!
Dec 31, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
317 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
