Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Error E18 with Canon Digital Camera IXUS 90i
How can I fix E18 error in my camera. It always appears when i turn on the camera. After the appearance the camera getting hank and turn off automatically.
Thanks.
Elsa
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 19, 2010
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
E18 appears in lower left part of screen when camera is turned on
The E18 error is fairly common on certain Canon models. Here's a link to information on what usually causes it and how to fix it. http://www.e18error.com/
Apr 04, 2009 | Canon PowerShot A85 Digital Camera
E18 appears on the camera and the lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Aug 02, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Camera does not start up
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 21, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Problem with E18
The "E18" error code indicates an error that involves the lens unit or lens cover. Or it may appear if you apply pressure to the area surrounding the lens while handling the camera. Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Oct 02, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
