Question about Dryers
No heat (Frigidaire Crown Series Dryer)
The dryer comes on, the tub rotates, but the dryer never heats up......I replaced the gas valve solenoids but there is no heat...The heat may
come on when the dryer is first turned on. But it goes out and never comes back on. Please help.
  • youtrygod Jan 31, 2009
    We have the same problem. The tub spins but there is not heat.
  • robert samples May 11, 2010
    did you replace the ignighter just because it glowes dont mean its good
watugot
  • 290 Answers
SOURCE: no heat
If your dryer has an access panel at the bottom front remove it.  Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with  2 small blue wires going to it.    UNPLUG THE DRYER NOW    Remove the wires and connect them together.   BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked.  I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Posted on Oct 12, 2007
  • 156 Answers
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
  • 184 Answers
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Posted on Apr 10, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 184 Answers
SOURCE: Kenmore 80 series gas dryer not heating
THE SOLENOID IS A REPLACEABLE PART ONLY. GET YOUR
MODEL # AND PURCHASE A SET OF SOLENOIDS IF YOU ARE SURE THAT IS THE PROBLEM. THE INSTALLATIONS INSTRUCTIONS SHOULD BE IN THE PACKAGE.
BE SURE YOU CHECK FOR A BAD THERMAL FUSE, CYCLING THERMOSTAT, HIGH LIMIT THERMOSTAT, BAD
TEMPERATURE SWITCH, MOTOR CENTRIFUGAL SWITCH, TIMER, AND RADIANT SENSOR. THEY ALSO WILL CAUSE A NO HEAT CONDITION.
Posted on Aug 06, 2008
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Dryer heats for 10-15 minutes then cools
Then the heat does not come back on again by itself? Is RGS764KQ the correct Model number? Or RGS7648KQ1? Then replace coil kit, Thanks Sea Breeze
M Series Gas-Valve-Solenoid-279834-00928757
Aug 16, 2013 | Roper RGS7646KQ Gas Dryer
My Frigidaire Crown electric dryer isn't heating. The drum turns but no heat! HELP!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLER341A Electric Dryer
My firgidaire crown sereis gas dryer heats , turns and get warm not hot
heatman101
Sep 21, 2010 | Frigidaire FGQ332ES Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Mar 08, 2009 | Frigidaire Dryers
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Dryers Logo
323 people viewed this question
Top Dryers Experts
