Question about Brother MFC-7820N Printer
Is there a reset or fuse to restore power on a brother MFC-7820N
Please advise if there is a reset or fuse to replace to enable power to be restored on a brother MFC-7820N
Power went down and once restored I have no power on my printer
  • ozetoys Mar 02, 2009
    Thanks heaps...that fixed the problem. I was able to solder a new fuse in and away I went..
    Thanks again
  • kbedi May 02, 2014
    MFC-8480DN does not have that metal plate. It is a one piece black plastic grid that has some wires and cooling fans mounted on it.
Yes, there is a fuse, two actually, inside the unit. My 7820N died after a power surge. here is how I fixed it.
unplug the power cord
raise the glass/ feeder assembly
open the front cover and remove the toner cartride.
Remove the phillips screw on the right side of the printer (same side as the power switch)
open the back paper path cover and remove the phillips screw
Flip the printer on its side and using a small screwdriver, press in the tabs that hold on the side cover. as with everything plastic, be careful since things break easily.
Once the side cover is off, remove the screws holding down the large metal cover over the power supply
Remove the screws holding the circuit board.
remove the three connectors on the front side of the board and flip it around.
By the time you have reached this point, you have probably noticed little pieces of fuse and MOV scattered around the inside of the unit, assuming you had a good power spike.
The fuse that blew for me as a 4 amp, fast blow fuse. It is soldered into the circuit board. I unsoldered the ends of the fuse that remained and soldered in a new 4 amp 5x20mm fast blow fuse. the MOV was also blasted, but I didn't have one of those to replace it and you can't get them at Radio Shack. I'll just plug it into a surge suppressor which will accomplish the same thing.
After reassembling, I was back in business.
Posted on Mar 02, 2009
Brother MFC-J4610DW is there a fuse replace inside?
replace a new power supply of your printer..
Jan 26, 2014 | Brother MFC-7820N Printer
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
I cannot get my Brother 7820N to print now that it is hooked up via USB to an Airport Express. It was working fine via ethernet cable to wireless router. Any suggestions?
simply restore the computer to the back date
and check the print
Click on start - all programs - Accessories- system tools - system restore -
Feb 23, 2010 | Brother MFC-7820N Laser Printer
How do i reset the drum
To reset the drum, please try opening front cover of the machine,hold down clear button,when it ask you if you replaced the drum you select yes.Then you're done!
Regards,
Jeep Brainy
Sep 17, 2009 | Brother MFC-7820N Printer
I have just replaced the drum in a brother MFC-7820N, now all I am printing is solid black pages, can you help me please?
Sounds like a defective drum, the corona wire could be broken, Brother will warranty for 90 days and you can exchange, if it's generic you should take it back and exchange it.
Sep 10, 2009 | Brother MFC-7820N Printer
Problems with Brother MFC-7820N Laser Printer turns itself off
I just had same issue, it shared an outlet with a large volume work group copier, I unplugged it, opened and closed all compartments to make sure something open was not causing issues. I plugged it into different outlet and it appears to be back online. I have read some postings that this model has been known to draw over 15 amps. Its possible its starving for power. To test take to another room, plug in outlet by itself and see if it boots up.
May 29, 2009 | Brother MFC-7820N Laser Printer
Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
1,387 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
