Question about Lasko 5365 Ceramic Compact Heater
Dont know what buttons mean
I have some sort of lasko pedestal heater with a circular button system on top with the on/off button in the middle. Well, that is the only button I can understand. What do the others do and in what order? No manual. ???
  • lasko 5355 ceramic space heater. I need a users manual
    Sergeant:
    Champion:
  • 205 Answers
Hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Posted on Jun 22, 2009
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Morphy richards electric blanket --how to use it
the 0 and 3 settings are to set it to come on in 3 hours (0 being off). the 1,3,12 settings are for it to turn off automatically after that amount of hours. I can remember what the 1/2 button in middle is for.
Jan 27, 2010 | Heating & Cooling
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
http://laskoproducts.com/instructions/5364Ins5364ES.pdf
Here you will see what the buntons do.
Good Luck and Please rate Fixya!
Jan 08, 2009 | Lasko 5365 Ceramic Compact Heater
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Nov 30, 2008 | Lasko Ceramic Heater
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Broken bracket on lasko pedestal fan
I have the same problem. Called Lasko parts department and got one. http://www.laskoproducts.com/
Description of part on invoice - 05098021T BAG HDWR BASE T/BLK 30PTEXTURE BAG
Cost $7.50 for part plus shipping to me was at $6.61 so it was pretty cheap. Comes as a package with four screws/washers/nuts. Hope this help someone out there.
Sep 08, 2007 | Lasko 3135 Stand (Pedestal) Fan
Lasko 5365 Ceramic Compact Heater Logo
833 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
