FixYa.com
Tags:
Compaq UPS R3000  UPS System
Less then 5 minutes runtime at minimal load (by 3 users)
posted by kissszilard on Jul 26, 2007
When there is low load level connected to my Compaq T1000H or R3000H (ex. 1 monitor to a r3000h), turns off after ca. 5 minutes. Restarting the ups runs another 5 minutes and turns off again. I think this is a matter of settings. Can anyone help me where can I set this option ? Which software or can it be done from its hardware ?
Comment by kissszilard, posted on Aug 28, 2007
The batteries were changed 2 months ago. I wrote that the ups turns off automatically running on batteries after 5 minutes with minimal load, but I can restart it pushing the ON button, and like this runs for another 5 minutes and so on. (without recharging). I can repeat this x times, the batteries are full and don't discharge so quickly with this minimal load...
I have the failsafe and lansafe software but haven't found any setting regarding to this.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ali akbar, posted on Apr 23, 2008
less then 5 minutes runtime at minimal
Comment by Guest, posted on Nov 07, 2007
I've got the same problem with compaq R3000h (not hp) ups. Works just only 5 minutes on bateries and turn off. Does anybody knows how change hardware settings in this ups?
thanks for help
Piotr
Best Solution
posted on Aug 26, 2007
Helpful (85)
Zt3000
Rank:Guru Guru
Rating: 86%, 281 votes
You gave no reasons why you thought it was simply a software setting, so I gave you a link below for some management software.
The HP R3000 UPS supports HP Power Management Software (CPM) version 1.8.
http://h18004.www1.hp.com/products/serve...
In addition the HP R3000 UPS also supports the LanSafe III management software (discontinued).
My first question is: When were the batteries last changed?
If they haven't been changed in 3 or so years, then it's probably low batteries, meaning they are old and cannot take a charge anymore.
ZT3000
Beta tester of "0"s and "1"s
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these UPS Systems Devices problems?
UPS Systems Devices
SURT8000XLT ISSUE
hi team, i got a consult about... Answer This...
UPS Systems Devices
instructions to connect KB...
After battery change I need... Answer This...
UPS Systems Devices
powerware personal 1000
I am using this unit an an aide... Answer This...
UPS Systems Devices
Installation with Cordless 2.4...
I do not know how it works Answer This...
Compaq UPS R3000 (242705-001) UPS System
Compaq R3000 (Doesn't power up)
I recently came across one of... Answer This...
Repair Service
Find UPS Systems Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
