Boom comfortmaker furnace will have a loud rush of flame b4 blower will turn on.
  • 700 Answers
Your experiencing wjats called in the trade as post ignition and unless you have exstensive knowledgre of heaters i would suggest that you call a qualified service technician out to correct your problem.
Posted on Jan 29, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Code 12 on furnace
dont know what code 12 is but could be a pressure switch that acts like a flame sensor
Nov 20, 2013 | Heating & Cooling
York furnace 7 flashes
If the light flashes red 7 times, the furnace is not sensing flame. Check for a flame sensing rod (small steel rod in the path of the main burner flame). If you can see it, shut off the furnace, and clean the rod with a rag soaked in vinegar. Turn the furnace back on and see if this cures yyour fault. Make sure you turn the power off to the furnace and then back on as this will reset the circuit board.
Jan 05, 2013 | York Furnace Draft Inducer Blower Fasco #...
I have a goodman gpmn furnace. The ignitor lights, and then the flames turn on, then the blower kicks on, and about 30 seconds later the flames turn off, and the blower continues to blow air. We have tried...
Hello, looks like you limit switch keeps opening because your furnace is overheating, Check your air filter and blower wheel to make sure it is not dirty and make sure you blower motor is moving at the proper speeed. Usually when air flow is cutoff the limit switch will open.
Feb 15, 2011 | Goodman GMS90703BXA Heater
I have a York Diamond 90 furnace and when i try to start it, the pilot light goes on then it shoots the flame into the furance, but will shut down a minute or so after that. It sounds like the blower is...
The furnace is not sensing the flame. Turn off the power.
There is a metal rod in front of the last burner to light. It is corroded and needs to be cleaned. Its the flame sensor .
take the 1 screw out holding it in to the bar and scrub it with some steel wool till shiny. replace and turn on furnace. all should be fine.
Mar 30, 2010 | York Furnace Draft Inducer Blower Fasco #...
Where can i find a manual for an old comfortmaker gas furnace that's about 50 years old. The model #GC400050-08M. The blower works and the pilot light is on, but no heat is coming out of vent. The flames...
Tie red and white wires together after removing thermostat from wall, if unit comes on replace thermostat, if not check limit controls for continuity, Good luck.
Mar 02, 2010 | Heating & Cooling
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
Furnace shuts off once the flame comes on.
You are having problems with your air/fuel mixture. It would be best to call a tech that knows how to work with propane. This type of problem is fairly common when using propane.
Aug 19, 2009 | Intertherm P3RA-048K Air Conditioner
Comfortmaker furnace goes boom
yoiu need to call out a qualified service technician to repair this situation immediately. What your hearing is called post ignition meaning that the gas is building up inside of the unit and then exploding.
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
