Question about Panasonic SV-AV50 Digital Camera
Check Card Hello, I bought the Panasonic SV-AV50 here in Iraq. I also bought a memory card to go with it. When I put the card in, everything turns on fine, the card goes in smooth and removes just as easily, however, I cant record photos or video on to it. Instead it displays "check card." What do I need to do? Thanks!
  • Anonymous Apr 09, 2009
    i have the same check card problem.. and i have it in record mode.
    Problem Solver:
  • 32 Answers
R u taking it on memory or video mode. If camera in play edit mode then it will neither take pic nor video please chek Sangita
Posted on Jul 26, 2007
SOURCE:
Formmatted memory card showing check card
You don't state the type nor capacity of card you're attempting to use, but the problem you describe is typical of having used the wrong one.
Your SV-AV50 is compatible with SD cards only up to an absolute maximum capacity of 2GB. I strongly suspect that you have tried to use an SDHC card which will fit in the slot and looks the same, but as a later development it's incompatible with all hardware designed for regular SD cards only..
Your camera cannot be updated to use SDHC cards, so if my guess is correct then your fix is to use the correct card type.
Another possible cause is if you have formatted the card via your computer. You must never do this, always re-format in the camera only. If that's what you have done then with a fully charged battery try to re-format the card in your camera, but sometimes this doesn't work and the card cannot be used in the camera again.
The final causes are that either the card has failed or that the camera has failed. The first can be fixed by replacing the card (many major brand names will replace them even if the warranty has expired), the latter is not a DIY fix and the camera would need a professional repair, but you can buy brand new, no-name, basic models of similar or better specification for far less than the repair costs to yours.
Jul 22, 2011 | Panasonic SV-AV50 Digital Camera
SD Memory Card
Yes. The SV-AV100 comes with a 512MB* SD Memory Card. The SV-AS10, SV-AV50 and SV-AV25 all come with an 8MB* SD Memory Card. *Usable capacity will be less.
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Format the SD Memory Card
Formatting erases all the data recorded on the SD Memory Card. If an SD Memory Card becomes unreadable, formatting may make it reusable.
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
SD Memory Card
SD Memory Cards
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second).
Difference between MPEG2 and MPEG4
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). * FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. * NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher.
Panasonic SV-AV50 Digital Camera Logo
138 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
