Question about Sony Cyber-Shot DSC-P8 Digital Camera
Won't turn on
Similar problem I've been seeing here. I press the power button, the tones start indicating that it is turning on, but it stops - and nothing. I have had a problem in the past with the lens sticking, but gentle tapping around the lens area freed it up. That's not working this time.
  • kaili-killjo Jul 13, 2008
    Hit the power button, nothing happens no lights no sounds nothing. but i got a new battery and it was working fine this morning but then after ten minutes it flased the dead battery signal and now neither batteries work
  • 64 Answers
Looks like its time for the repair shop. Once these gears get fried up for real, they need to all be pulled out. It needs to be sent in. Just like a clicking hard drive, having to manually do anything on a digital point and shoot is a bad sign! Hope this helps!!!
Posted on Jul 26, 2007
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
X9575 won't power on
Check with Lexmark to see if there is a reset button for unit
Aug 22, 2017 | Lexmark X9575 InkJet Printer
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
HOW DO I TURN IT OFF AT NIGHT? IS THERE A SLEEP MODE?
Here are the steps to turning your headset on and off.
Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending tones.
Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending tones. When power is off, indicator stays off.
Good luck from Headsets Direct - 800-914-7996.
Aug 12, 2011 | Plantronics Explorer 230 Bluetooth Headset
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Good luck from Headsets Direct!
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 | Swi Watches
Sony Cyber-Shot DSC-P8 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
