Question about Sony Cyber-shot DSC-W50 Digital Camera
Problem to see my photo
The first, i copy my photo from DSC-W50 to my PC and then i edited that photo.. after i finished my work i copy again into my sony DSC-W50. And what i get is i can't see my picture that already edited, but the real photo still i can see. Wierd..!
What is the problem??
Sorry if my English bad. :)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Many cameras simply will not display edited photos, or photos taken by a different camera. This is because the camera cannot be certain of the format and parameters of such "foreign" photos.
Remember, the camera is a device for taking photos, not for showing them off.
Posted on Feb 27, 2012
SOURCE: Access problem in DSC-W50
I had the same problem described here and read that you can bang the camera as you power it on. I banged my DSC-W50 while powering up, at first lightly with increasing strength each time. It started working after the 3rd impact.
Posted on Sep 01, 2008
SOURCE: Sony Cyber-shot DSC-W50 issues
Great explaination.
I tried this reset, but the error came back. Read in other posts that it is a "flash capacitor" problem.
Posted on Apr 15, 2009
Rammsteins
  • 300 Answers
SOURCE: Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at toms.safranovs@gmail.com or contact your local Sony service center.
I work in a Sony service center.
Tom
Posted on Jul 28, 2009
taran_2005
  • 10515 Answers
SOURCE: Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
  • 11967 Answers
SOURCE: DSC-w50 says ACCESS when powering up.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 20, 2009
When I try to load pictures from the DSC-W50 camera to my PC, it says : file BOAKaa.EXE cannot be found. I do not have the CD-ROM for Cyber shot Application Software. If the solution is available free of...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa program ( htpp://picasa.google.com ).
Sep 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
What do you do when it says no memory space in the memory stick?
usually you can offload your photos and reformat the disk... once that's done you should have space again. if not there might be a defect in the stick.
Nov 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot W50 camera I cannot find the 'read this first'
After you download all the pictures, format the memory card will delete all the pictures on the card.
Here is a link for the user's guide Sony Cyber-Shot DSCW30/W40/W50/W70 Uesr’s Guide
Jul 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I retrieve photos from my built in memory storage if I don't have a camera to computer hook up wires?
Put memory stick in camera, power up and press Menu on camera, select Copy option and press OK
That will copy photos from internal memory to memory stick.
Jun 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Transfering to my desktop
does your cam comes with an installation cd if it does install the software and follow the instructions. If you do not have the cd and you saved the photo on a memory card simply connect a card reader to your pc and copy it directly from the memory card
Dec 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Free installation on line for DSC W50
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Nov 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I dropped my Sony DSC-W50 camera with the photo shot mode
Some problem in the lens system.
Try to either push in the lens more, or pull on it, if the lens is out at all.
If it continues, sell it for parts, as is on a site such as Ebay.
Jul 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Date on print
Are you using the PictBridge compliant printer for the prints? If so click here to read page 75 for the setting on the printer. Go to the bottom of the PDF file, use the arrow to go to page 75. Don't follow the paging on the manual book itself, because this is a soft copy of PDF.
If you get prints from photo finishing center, then you probably have to order prints with date and/or time stamp added on.
As far as I know, W50 has no time stamp setting. Every image file carries its own date and time for printers to add the time stamp if printer has that function.
Hope this can help.
Jul 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lost disk dsc-w50
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
