Question about Olympus FE-280 Digital Camera
Jammed lens I dropped my lens and now they are jammed so i cant even use it. I need it fixed by march 2009 for my trip to scotland. Please help me!
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Olympus Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Olympus refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
Posted on Jan 29, 2009
How to fix a canon powershot lens
Here are troubleshooting steps for a lens error. Since the camera was dropped, and the lens is canted, suggest proceeding directly to Fix 7. And here's a video summary of the steps.
Jan 22, 2013 | Canon PowerShot SD880 IS Digital Camera
I've got an Olympus E-500 kit lens, it's a 14-45 mm and I dropped it a while back, and it doesn't auto or manual focus anymore. I wanted to see if I could take it apart and fix it for myself, and I took...
ONE - unless you have done this before - and it seems you have not - don't even try it. You should be able to get the lens off of the body without unscrewing anything - can you do this? If you can then you should go to a camera store that has olympus glass and see if changing the glass helps - most problems like this are because the lens got jammed - if you are lucky. I cant tell you how many smart people think they can fix a camera themselves - I have cleanrooms at my disposal and have been a pro for over 25 years - I have fixed many of my blunders but jammed glass and digital bodies are way above my capacity - and probably yours too.
Apr 20, 2010 | Olympus 40-150mm f3.5/4.5 Zuiko Lens
Camera not staying on LCD display message.
Remove the batteries and externally recharge them . Sometime batteries , in some cases can have a polarity change but then the camera may just not turn on.
Jul 27, 2009 | Canon PowerShot A470 Digital Camera
I have a lens issue (possibly jammed from lens cleaner i used?)
A nice lens brush is what you clean a lens with.
Solvents in the spray you used could have done a couple of bad things.
1. Carried muck into the zoom mechanism.
2. Melted/dissolved part of the zoom mechanism.
Either way, unless you are brave and capable enough to dismantle it, it needs to go back to service for a clean out/re-jig.
Sorry for the news,
dave.
Mar 20, 2009 | Kodak EasyShare DX7590 Digital Camera
Dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Jan 08, 2009 | Nikon Coolpix S210 Digital Camera
Lens Broken
the lens is what the camers sees somewhat like the human eyeball, you loose your eye you can't see, brake the lens the camera cant see
Jan 03, 2009 | Cameras
Do you know?
just give the lens a very light jiggle when you happen to think about it..thats what i did...kodak offered to replace the camera even ..or as they say repair it...but i jiggled one day and it worked..
my thought to this something enviromental was lodged in it. hope it helps
Aug 25, 2008 | Kodak EasyShare V1003 Digital Camera
JAMMED LENS
The track inside of the lens and maybe other damage has been done. This is something that you cannot do yourself, unless you are trained, have access to the parts, and experience in camera servicing.
You should send the camera to the manufacture authorized service rep for an estimate.
Apr 14, 2008 | Samsung Digimax S600 Digital Camera
Cannon Power shot SD630 Lens Problem
Sorry to here that you can send it to a repair company like me for repair. cost about $120.00 plus shipping to fix.
Feb 26, 2008 | Kodak Easyshare M753 Digital Camera
DMC-FX8
If the lens is jammed in the out position you can try holding the camera firmly and tapping/hitting it against your hand with the camera on. The lens should then retract. If this doesn't work or if you are afraid of dropping it (do it on your bed, that way it doesn't hit the floor if you _do_ drop it), you can drop it on a wood/firm surface from an inch or so up and it should retract the lens. This solution ONLY WORKS IF THE LENS IS JAMMED.
Sep 30, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Olympus FE-280 Digital Camera Logo
140 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
