Question about Sharp AL-1641CS Color Copier
TWO SIDED COPIES
WHAT BUTTON DO I PRESS ON THE DISPLAY TO MAKE TWO SIDED COPIES
    Champion:
  • 320 Answers
You need to press the duplex button to do 2 sided copies
Posted on Jan 29, 2009
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
300ci will not copy 2 sided documents
from the copy screen touch the duplex button on the display and choose 2 sided > 2 sided. if it is not available in the menu the duplex unit may have failed repeatedly and shut itself down in which case you would need to go into simulation mode and perform a u906.
Sep 29, 2014 | Kyocera Taskalfa 300ci With Feed, Bank,...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
How do I make double sided copies
On the basic menu press the simplex button then press 2->
Aug 03, 2011 | Toshiba e-Studio 350 Copier
I wont you to help me as to how i can make a photocopy using my canon ir 3100cn machine. than you
have you ever operated a copier? it,s so simple place the originals face up on the DADF. SELECT the no. of copies. there will be option available on display for selecting whether you want B&W or color copies like b&w, auto color, full color etc. there will be copy ratio button for zoom(25%-400%). Now press start button.
For two sided copying press "two sided". There you will have mainly two options (i) 1>2 sided:- converts two single sided documents in to a two sided copy (ii)2>2 sided:- converts a 2 sided document into a 2 sided document. normally both will be done in book type for normal orientation.
Apr 11, 2011 | Canon iRC3100 Printer
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
Sharp AL-1641CS Color Copier Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
