Question about Texas Instruments TI-83 Plus Calculator
Cube roots or higher
If i am trying to do anything with cube roots or the 4th roots or any thing like that. what keys in which oders do i put them.
  • 4 Answers
If you want to take the nth root, enter the root first then press math 5 and then the number you are trying to take the root of.  For example to take the 4th root of 1000, press 4, math, 5, 1000, enter.
Posted on Feb 03, 2009
How do you put in radicals in the casio fx-300ms
Use the square root key. For roots of higher index, use the xRoot key; the shifted function of the Y^x or [^] with exponent 1/3 for cube root, 1/4 for 4th root, or 1/n for the n-th root.
Jul 14, 2014 | Casio FX-300MS Calculator
How do I simplify a cubed root of a number on the fx-300ES?
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Apr 18, 2012 | Casio fx-300ES Calculator
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
Aug 11, 2011 | Texas Instruments TI-30XA Calculator
How to find the Cube Root using TI-30XIIS
Hi there,To find the cube root, you need to press 3, then press the 2nd key, then press the ^ key (4th below the 2nd key), then press the number you want to cube root.
Cheers,Alex
Jun 06, 2011 | Texas Instruments TI-30 XIIS Calculator
Trying to find the surface area of a sphere given the volume: V = 4/3 X pi X r cube problem given vol. find the surface area v = 5000 5000(3/4 pi =r cube the book reads: 3 cube before and the square...
Almost exactly the way it's written in the book.
In the LineIO mode press
3 SHIFT [xth-root] 5 0 0 0 * 3 / ( 4 * SHIFT [pi] ) ) =
In the MathIO mode press
SHIFT [xth-root] 3 right-arrow 5 0 0 0 * 3 / ( 4 * SHIFT [pi]) =
xth-root is the shifted function of the key just below and right of the big round cursor pad.
* is the multiply key
/ is the divide key
pi is the shifted function of the x10^x key in the middle of the bottom row
BTW there's no "square root" in this problem. There's a "cube root" or "third root". Square root is the second root.
May 14, 2011 | Casio fx-300ES Calculator
Can I use the ti-30xa to find cube root, 4th roots, and 5th roots?
Use the x-root function, which is the 2nd function of the y^x key located just above the divide key. For example, to find the cube root of 8, press 8 2nd x-root 3 =
Nov 14, 2010 | Texas Instruments TI-30XA Calculator
Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
May 27, 2010 | Texas Instruments TI-30XA Calculator
Is it possible to calculate cube root or higher with BA ii plus?
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Feb 21, 2010 | Texas Instruments BA-II Plus Calculator
How do I solve radical expression and equations using the TI89?
1. square of 12
2. cube root of 48 a raise to 5 y raise to 6
3. square root of 128 y raise to 5
4. 6th root of 9 y raise to 2
5. cube root of 24 y raise to 5
6. 10th root of 32 x raise to 5
7. 15th root of 64 x raise to 9
8. 4th root of 10000
9. cube root of 192 p raise to 5
10. cube root of 256 y raise to 12
Jul 04, 2008 | Texas Instruments TI-89 Calculator
Cube roots
You use the y^x (y to the x) key along with the 2nd function key. That does the opposite operation.
So, let's pick something we know the answer to as an example. How about the cube root of 8? We know 8 = 2 X 2 X 2, so the cube root of 8 will be 2.
Here's how:
8 2nd y^x 3 =
The display will show 2.
The three is the root you want. You can put in any number, with 2 being the square root, 3 the cube root, etc.
Mar 23, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-83 Plus Calculator Logo
1,502 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
