Question about Sony DAV-S888 System
Dvd locked My husband was moving our dvd player and some other equipment around and hooked it back up and it said locked. It won't open, and we can't get it open. The owners manual says nothing about what to do when your dvd player locks up. What do we do? We've already tried holding the stop and eject button for a few seconds, but it was of no use.
  • asset1 Mar 08, 2009
    A for angel!. Mine got burgled and got it back through some thug I fortunatly happened to know, who couldnt get it working coz it locked itself Ha Ha!
    Anyway its working now. I cant live without my music! Thanx.x
    Sergeant:
    Champion:
  • 326 Answers
Hello, try pressing stop and eject for 5 seconds. If you need more info please advice. Arpi
Posted on Jul 27, 2007
  • Arpad Kothai
    Arpad Kothai Jul 27, 2007
    Hello again.
    This is an in-store display anti-theft feature.
Locked sony dvd
Posted on Apr 22, 2011
Arpi... YOU ROCK! I don't know how the hell my drawer got locked in the first place but this solved it! THANK YOU!!!
Posted on Aug 23, 2007
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
My emmerson tv won't change to the channel i need so i can hook up my dvd
Is the player hooked to the cable/coax fitting or the audio/video jacks?
Apr 24, 2012 | Emerson Televison & Video
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
Cannot find an unlocking code for my new dvd player: Toshiba XDE600KB. 40% of my dvd collection is from region 1, when my husband was in Canada. We are in England (region 2) & none of them will play.
Kelly - If you have the EU version the following will work if they haven't upgraded the firmware so it won't work. worth a try. I couldn't tell for sure from your post exactly which wouldn't play, the region 1s or 2s.
  • turn on dvd player
  • open tray
  • press "35147199" on remote
  • turn off dvd player
  • turn dvd player back on & you should have an open region player
If it's the US version there is no known Region Hack (At least that I could find).
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 17, 2011 | Televison & Video
I have Dish network and a Sanyo dvw7100.I moved and cannot find my maual. I need to know how to hook it back up.
Hi my name is Mike Houston of DISH Network and I was readingyour post and see you moved and need a manual to connect your system. I willsend the link to help with the equipment you have, http://www.dishnetwork.com/supportsection/manuals.
Oct 29, 2010 | Sanyo DVW-7100A DVD Player/VCR
Rarely used equipment. When hooked up went into
The default password is 3-3-0-8
regards,
James
Mar 31, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Apr 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Dvd player is locked
If there was a dvd in the tray and the cable guy moved the dvd player, there's a good chance the disk might have slid off the tray and is now blocking the tray from opening. Also if the machine was moved there is a good chance the tray/laser lock might be on. It is a switch or button located on the bottom of your dvd player. Check your manual for exact placement. It is built in for shipping purposes so they don't get broken from rough handling. Hope this helped!
Jan 12, 2009 | JVC THC6 Home Theater System 5-Disc...
My kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Dec 28, 2008 | Televison & Video
DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Sep 16, 2007 | kawasaki SVP500 Multi-disc DVD Player
Sony DAV-S888 System Logo
1,067 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
