Question about HP PSC 1315 All-In-One InkJet Printer
My printer when i try printing, my page said save
    Scholar:
  • 24 Answers
Hi Crysti,
Hey Crysti, the issue is with the printer settings.
What you need to do is, just uncheck the option "Print to file", when you give the print command from the computer.
Steps:
1. Open the application you were trying to print from.
2. Click on file and select "print"
3. It will open a print window, where you can able to select the number of copies and other options.
4. Here you will see an option "Print to file" option. Just uncheck it.
5. Then click on the PRINT button and check for the results.
I am pretty sure, this will resolve the issue.....
With Regards
Mike...
Posted on Feb 07, 2009
Is printed documents saved in the printer
Afraid not! Windows often saves a document automatically if it is recent. Go to Start>My Documents.
If that fails try a Search for the title of the doc.
Go to Start>Search>Documents the give any details you can
Apr 02, 2014 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
Printer will not print from email
if you wan to print an email . go to the actually web page ...and try from there ...do not try to print from outlook cause it has an encoding that might not be read by the printer ...specially for attachments ...
if you wan t to print an attach ment ..save it in the computer first ...
if you want the whole page ...print it from the website of the email service ...and use file(left -top) and print ...for yahoo for example you can print from the page directly by using the print job on the right corner of your email ...Im sure that for about any email service there is a thing like this ...
in sort ...usually is best to save any file that ya want to print into the computer before..
Dec 21, 2009 | HP Photosmart C6280 Printer
Prints documents straight from PC, but printing from internet bad
Try to save the save the page into single file then try to print.
Aug 19, 2009 | Samsung CLP-300N Laser Printer
Printer will not save photos to computer
For whatever reason, it sounds like the printer cannot communicate with the computer. Check all the wire connections. If all connections are good, try printing a test page using Word. If you can print a test page, that shows everything is workign properly. Next, try uninstalling and reinstalling the software that came with your printer. If you do all these things, that should fix the problem unless there is something wrong with the printer hardware. Good luck.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
My Konica Minolta magicolour 2500w won't print web pages any more
I believe it is a Windows problem and not a printer problem. Try to print from a different application, to see if it is working.
Jun 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Unable to print text documents
Some times image/picture files are very big files. That big size, in mega-bytes, some times conflicts with your amount of available memory. It could effect the print que or ram. Try running the file through a picture editing program edit the files then rename and save them. You can check the file size prior and then after you run the file through the program. If the file size is lowered it should print.
Nov 07, 2008 | HP - HP Photosmart 8250 printer
HP PSC 1315 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
