Question about Acer Extensa 4620 Notebook
Laptop not reading camera memory card
Hai,
My Acer Extensa laptop is not reading my Nikon Cooolpix camerea memory card. I want to copy pictures from it. Wht do i need to do?
Regards
Lavanya
  • 404 Answers
Hi Lavanya,
Some machines can't read large capacity Sd cards my old Hp Nx6125 could only read max 1Gb. If your card is larger then you may need to purchase an up to date external card reader, most read up to 8gb and are not expensive.
Hope this helped? if it does please remember to press the Blue button for my FREE effort!
Paul 'W' U.K.
Posted on Jan 29, 2009
I have a nikon coolpix p80 and i need to transfer pictures form the camera memory to the memory card.. how do i do it?
You can do it through computer, using a memory card reader or there are many new laptops are with a inside memory card reader too, then you can transfer pictures from the camera memory and to the memory card.
Dec 30, 2010 | Nikon COOLPIX P80 Digital Camera
Will not upload pics nikon Cooolpix S550 Windows Vista
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Nov 28, 2010 | Photography
Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Dec 26, 2009 | Nikon Coolpix 4600 Digital Camera
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Aug 09, 2009 | Nikon Coolpix 4100 Digital Camera
Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Apr 22, 2009 | Nikon Coolpix 5700 Digital Camera
How do I download my camera's memory card onto my acer extensa
The "odd shaped port" you are referring to is most likely:
The Express Card slot (replacing the slot known as “PC-Card” replacing the slot formerly known as “PCMCIA”) are the biggest standard slot on a laptop designed to handle stuff like wireless cellular modems with antenna and micro hard drives. Most people won’t ever use this slot, but it’s a lot faster than it’s old relatives now that it connects directly to PCI-Express. From: www.geek.com
Do NOT put your memory card from your computer into that slot. Since you have indicated that the USB cable connector option will not work, you will have to go out and buy a memory card reader that is compatible with you memory card. They are relatively inexpensive and easy to find at most electronics stores. Plug in the card reader (USB) and seat in your memory card and the OS of your laptop should detect the card and allow you to download the pictures.
Hope this helps!
OpenSource13
Apr 05, 2009 | Acer Extensa 5420-5687 Notebook
While copying pictures into my computer i formatted the card  affter copying the pictures & since then my nikon camera is saying memory card cannot be used
Always format memory cards from the camera, never the computer. The camera has an operating system that may not be able to read your computer's system. Try reformatting the card in your camera, See if that works.
Mar 14, 2009 | Nikon Coolpix 5700 Digital Camera
Cannot transfer pictures from camera to computer
Try formatting the memory card before inserting it into the slot. also try using the memory card that you were using before you got all these problems
Jan 09, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Camera/Acer Laptop
Hey kholcombe252,
I'm assuming this means you have formatted the memory card. If this is the case you could purchase a memory card reader that connects to your PC via a USB port, and you should be able to copy and paste your images back to the memory card.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Nikon COOLPIX L3 Digital Camera
Acer Extensa 4620 Notebook Logo
232 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
