Lennox air conditioner is blowing hot air
My air conditioner is on and the fan is blowing but the air is not cold. I have tried to press the blue reset button on the condenser outside but nothing happens. Is there something else I can do?
  • 3 Answers
I have a lennox pump that blows hot hair when the ac in on but the heat works. but when the ac is on hot air still even on 55 degrees. the blower in my attic blows out air and the pump is on outside any help
Posted on Jun 20, 2012
  • 359 Answers
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Posted on Jan 29, 2009
WOW,,thank you chech it like you said and lord and behold replaced the capacitor and works great and saved me a lot of cash i did not have to spare !!! knowing is a great and ween you share your know how !!!and it helps wow
Posted on Aug 22, 2010
Lennox 10hpb
change run capacitor on fan. or bad fan motor
Jul 06, 2014 | GE Zoneline AZ38H12DAD Split System Air...
Air conditioner blower won't run
need too check your orifice tub it could be colgged but make sure you check first your high pressure switch
Jun 18, 2014 | Lennox Armstrong Furnace Control Board...
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run...
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Jul 20, 2013 | Heating & Cooling
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
I got a lennox xc13 air condtitioner,not blow cold air
When was the last time you checked or had the freon level checked.
Aug 02, 2009 | Heating & Cooling
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
Nissan Altima no cool air blowing or hot air blowing
Hi!
It appears we have an Air lock scenario and you will need to perform a system Bleed.
Park the vehicle on level ground, when cold remove coolant filler cap, start engine and leave to idle, turn heater on full and blower to max. When engine reaches operating temperature watch and listen near coolant filler, keep clear as gurgling and hopefully a boil over should occur. Top up with very warm coolant and wait as it may do it again.
Check for heat inside vehicle if warm replace coolant cap but keep an eye on temperature gauge as the ~Air lock may have moved on from heater matrix/core so proceedure needs to be carried out again from COLD.
Please press the Blue button to appraise my FREE Efforts, Thank You!
Paul 'W' U.K
Feb 24, 2009 | 2002 Nissan Altima
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Heating & Cooling Logo
2,573 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
