Question about Apple Mac Mini Desktop
My mac mini gets stuck on the first screen (gray with the Apple logo and the spinning wheel) and won't continue loading.
    Scholar:
  • 60 Answers
Start here...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Posted on Jan 29, 2009
My MacBook Pro was acting a bit strange; some websites wouldn't load such as Google, yet Facebook would. So I updated it then coming to the automatic turn on after the update my laptop gets stuck on...
This sounds like a possible filesystem corruption, possibly due to a bad update from Apple. What is the error that "Disk Utility Repair" gives you?
You may be able to take it to an Apple store to get your data restored, as they (sometimes) have special tools that scrape the existing data from the filesystem even if the metadata is corrupt.
Jun 18, 2013 | Computers & Internet
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
I have no problem turning on my laptop but it gets stuck in the loading screen. The wheel under the Mac Book symbol is turning and everything seems to be running just fine but the system itself is stuck...
Hi This could be one of three things. 1. a corrupted file on your HD, or 2. the directory on the HD is corrupted, or 3 a failing HD
Try starting up from your installation DVD and then running disk utility. (Insert your DVD then shut down the Mac. Restart the Mac and hold down the C key until you see the Apple logo. Once you reach the screen that asks which language you want to use, select English and then from the menu bar chose disk utility and repair HD)
If you get a message to the effect that disk Utility cannot repair the disk, run it one more time. If you still get the message then you had better locate a service centre.
Sometimes letting the installation run its course and overwriting the existing system will fix it. In this instance, you select the archive and install option, otherwise you will erase your files as the HD will be wiped.
I hope you have your files backed up.
May 02, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
My computer is stuck on the gray screen with the apple logo and spinning wheel only, please help I've spent over 8 hours trying to fix this Thank you very much!
you probably will have to insert your setup cd and reinstall you operating system---does "leopard" or "tiger" sound familiar?
Feb 14, 2011 | Apple MacBook PC Notebook
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Grey Screen Apple Start up issue
It appears there may be a possible startup item or issue with your firmware, which may be causing this issue, so I am going to provide some procedures in order to help you resolve this gray screen issue. But first, let me help you remove that disc first:
font.f1 {font: 13.0px Myriad Pro} font.f2 {font: 14.0px Myriad Pro} Procedure #1 - Ejecting CD from drive
Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly
• Reboot your Mac
• Hold down your Mouse button(s) prior to the Apple Chime
• Keep holding the mouse button down while your Mac boots up
• The disc should eject before you reach your Desktop
• When it does, simply release your mouse buttons.
If this does not help resolve ejecting the disc in your Macbook's drive, you are going to have to take more of a command-line approach:
font.f1 {font: 12.0px Helvetica} -EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal utility
• At prompt, type: drutil eject
• Now
press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard )en
• This command line should eject the disc from the drive, unless there are mechanical issues with the drive within your Macbook.
At this point the disc should be ejected from your Macbook. If this is the case, then I will now need to direct you back to Safe Boot mode, but with a little twist, from what you may have tried when you last when to Safe Mode:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Post back to me, if these particular Safeboot procedure does not help. Thanks!
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book only shows apple logo when turned on
This could be an issue where you may have a few Startup items in your StartupItems folder in your System Library which may be affecting your Macbook's startup.
So I recommend you boot your Mac into Safe Mode to see if you can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
Let me know if this helps!
Regards,
-Mactechtrainer
Jan 28, 2010 | Apple MacBook Pro Laptop Computer with...
Stuck on initial screen on power up
sounds like your hard drive died, you should take it into a repair shop unless you know someone that can replace the drive and re-install OS X for you. you computer uses a 2.5" laptop hard drive.
Jan 29, 2009 | Apple Mac mini G4 Desktop
Apple
Which screen is it stuck at? The spinning "gear"? The Blue progress bar scree? or the login screen? Answer this and i have your answer.
May 13, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Mac Mini Desktop Logo
1,101 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
