Question about Panasonic ER 203 Beard Trimmer
THE BLADE HAS COME OUT, AND IAM UNABLE TO REINSERT IT
PANASONIC ER 203
  • Anonymous Feb 06, 2009
    My Panasonic ER 203 Shaver Vlades Comes out . i m able to re fix it .. plz help...
  • bravonomi Feb 06, 2009
    MY panasonic ER203 shaver Blades comes out i m inable to fix it ... plz help me to fix it...
    thx
Poor website to get any helpful information, don't waste your time
Posted on Feb 01, 2010
    New Friend:
I opened the Panasonic ER2031 razor to clean and I do not no how to fix it back as the spring has snapped
r
Posted on Jun 09, 2013
Er 398 beardtrimmer
take off the blade, loosen two philips screws, wide blade slowly remove the upper from the lower half.....replace old with new batteries
http://www.akku-wechsel.de/shop/akkus/rasierer/akku-fur-panasonic-bart-haarschneider-er-398.html
Jan 05, 2014 | Panasonic Health & Beauty
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Ni Cd Batteries for ER203 Panasonic
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Aug 12, 2013 | Panasonic ER 203 Beard Trimmer
Need a replacement blade for ER240 beard trimmer in bangalore
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
Sep 06, 2011 | Panasonic ER 240 Beard Trimmer
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
May 12, 2011 | Panasonic ER 240 Beard Trimmer
ER203 NOT CHARGING,INDICATE THE RED LIGHT.WHAT IS THE PROBLEM PLEASE.
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
Hope this helps..
Mar 06, 2011 | Panasonic ER 203 Beard Trimmer
My Panasonic ER 203 with problem spring of
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Feb 14, 2010 | Panasonic ER 203 Beard Trimmer
Opening the Panasonic ER203
just insert a thin bladed knife between the two parts and gently lever apart
Jun 04, 2009 | Panasonic ER 203 Beard Trimmer
Panasonic ER 203 Beard Trimmer Logo
472 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
