Question about Sony Handycam CCD-TR748 Camcorder
What cable do i need to connect to tv
Lost av cable ,what type of cable do i need to connect to tv
  • 39 Answers
Any of the following 3 will work. S-Video ? Composite (Video) ? Audio (RCA) Information taken from: http://www4.shopping.com/xPF-Sony-CCD-TR748 images of S-Video cable and Composite/RCA cables listed below.
Posted on Jul 26, 2007
  • Stan Gasiewski
    Stan Gasiewski Jul 26, 2007
    Above: Svideo
    Below: Composite/RCA
  • Stan Gasiewski
    ***Please note that the Composite/RCA picture listed above is slightly incorrect and you will need a Male to Male cord** (Unfortunately fixya does not allow editing of posts so, the incorrect item is showing above.
    I have attached the correct image below:
SOURCE:
Trying to take tv off of av screen without the remote lost it
Turn off the device connected to the av output, then turn TV off and on again!
Aug 05, 2015 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
What kind of cable would I need to connect a DVD player to this combo, a RF Coaxial or AV cable?
Check the back of your TV for external input connections. Usually there will be one to three connections available for the various types of cables. Check the back of your DVD for the output connections, usually one to three as on your TV. Choose one and use the cable type that matches the DVD output and the TV input connections and you are done.
Feb 11, 2012 | Quasar VV-1302 13 in. TV/VCR Combo
Can I set up my older VCR to this TV? If yes how do I get it to work?
Hello
You can surlely connect this TV to your VCR, if the VCR has AV output with it at its rear side. Most VCRs will have this video out from it. Just connect this video out connection to your LGs audio video connection by using an audio video cable. This cable will be of three conductor type and can be bought from most of the electronic sparepart shops at your town. Choose a best quality one, when you buy it. After connectiing this cable with corresponding video IN sockets at the TV, switch ON both the devices and select AV2 or AV1 with the help of remote AV source button. The AV cable will have three conductors, a flat type cable haveing red, white and yellow colured RCA pint at both end. Coincide these colours to both TV and VCR when connecting it. That is all, and you can play your favourite video tapes by VCR.
gopakumarg43_25.jpgThe AV cable will look like this. OK
Aug 27, 2011 | LG 37LC7D 37 in. LCD HDTV
I AM TRYING TO CONNECT A DX-UPDVD2 PLAYER TO MY TV. I HAVE DVR FROM CABLE COMPANY THAT IS CONNECTED TO MY TV AND NOT ENOUGH PLACES TO CONNECT DVD TO TV HELP
Depending on what type of connection you are using from the cable companies DVR to your TV and what type of connections you have on your TV you can try the following..
1. As your DVD player supports HDMI, component and composite video out, check to see which spare AV inputs you have on your TV and connect the corresponding free input on your TV to the matching connector on your DVD player. You will also need to hook up audio from the player to this AV input on your TV using the options available on your TV (either RCA phono or optical in).
2. If you have no other AV inputs on your TV then buying an HDMI switcher or a component switcher or a simple an RCA phono y cable for composite video will allow you to connect both your DVR and DVD to the same TV input.
Hope this helps.
May 04, 2011 | Dynex Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Trying to connect a PS3 to my hotel room tv. I have 3 color AV cords, and I´m putting each accordingly on yellow, white and red, but can´t seem to see or hear anything on AV source. What am I...
did you set to AV 1, 2, 3 or DVD input, it is depend to where it connected to..whether you connect to the AV input front panel, or rear. if not sure you can connect it to the front panel and sequentially sets the AV source, if still the same. you can connect the cable to the DVD input should be the type of cable TV .. PS 3 is like this:
Connect red, green blue Plug/jack accordingly to each colour on DVD INPUT the TV. set AV Source to DVD.. please Try and if the same result , you have to replace the AV cable of PS3.
Oct 20, 2010 | Protron PLTV-32 Television
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
Connecting to my tv
A-V cable will be like below picture having 3 RCA pins Yellow Red & White colors.
Jul 11, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
5th generation ipod av cable
Check these links on how to connect your ipod to tv.
You have to buy a cable, which will enable it.
http://labnol.blogspot.com/2006/05/connect-ipod-to-your-tv-watch-videos.html
Or
http://www.podguide.tv/archives/2005/11/how_to_watch_ip.html
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Apple iPod MA446LL/A MP3 Player
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Sony Handycam CCD-TR748 Camcorder Logo
376 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
