Question about ASUS P4XP-X Motherboard
Memory problem on startup?
Upgraded ram ddr256mb with a 1gb ddr , now i get one repititive long beep even with the 256 module back in tried both sockets - p.s. unit sat in garage for aprox 2yrs very dusty but worked fine before attempt at upgrading ram - not sure which bios - system wont startup at all!
  • mjlilley1973 Jan 29, 2009
    re - installed original ram(256 mb) - same repetiive beep
    Sergeant:
  • 320 Answers
Well, according to your manual, Long beeps in a endless loop mean no DRAM was installed or detected. What type of RAM are you using? The problem is with your RAM only. if the frequency of your RAM doesn't matches your motharboard then it will not work. The frequency of RAM varies from 233MHz, 333MHz, 400MHz, 667MHz, 800MHz, 1033MHz etc.. and also it varies from motherboard to motherboard.
Thank you.....
Posted on Jan 29, 2009
  • Nagesh V Jan 30, 2009
    Clean the ram slot with vaccume cleaner
    thank
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Dec 02, 2012 | EliteGroup ECS P4VMM2 Supports Intel...
Compaq Presario R3000 2GB memory upgrade problem. I am having problems upgrading my Presario from 512 MB (2 x 256) to 2 GB (2 x 1GB). If both 1 GB DIMMs are installed, I get intermittent application...
Try a different brand of memory.
It is unlikely you can do anything with the memory you have to fix this problem.
The memory has the same specs as what another manufacturer recommends.
Be careful buying from auctions as they MAY be gradeouts. Always make sure you can return the product. Crucial has these for about $114 for your machine as an example.
Nov 13, 2009 | Compaq Presario R3000 Notebook
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
P4VXASD-R VIA Apollo P4X266-new 1G DDR gets 3 beeps
Well you said you used 256+128 and thats lower than 1gb. So try sticking in one of the stick and run it, see how it is. Then try the other, if both are working fine by themself then try cleaning your board with a nonscrathing cloth (or q-tip).
Lastly, just double check if your motherboard runs that kingston type, the pc2100.
As for your memory goes, os 2k can run up to 4gb of ram.
Jun 11, 2009 | EliteGroup ECS P4VXASD2 VIA P4X266A...
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Added ram, now wont boot long beep
try removing the ram and try again
Jan 04, 2009 | AOpen AX4B-533 Motherboard
E-machine not accepting new memory
try to check  whether the ram  frquency  matches the specifications....
any way  three beep  means a graphics card problem  so  if you have one remove it and try to reboot
but i think this has to do with the RAM frequency
pls do post back
Nov 26, 2008 | E-Machines eMachines W2686 PC Desktop
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
ASUS P4XP-X Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
