Question about Minolta Maxxum 300si 35mm SLR Camera
Need a lense
I have a minolta 300si camera and i the lense on it broke and i cant adjust the shutter cause of the platic piece broke off form the lense itself..will ant minolta lense work?
  • 14 Answers
SOURCE: minolta maxxum 300si 35mm camera battery
It takes either: Energizer 475 or Duracell 245........if camera still will not fire, your camera has a problem. www.flcamerarepair.com
Posted on Jun 29, 2008
Agent Allan
  • 480 Answers
SOURCE: minolta maxxum 300si (Filters?)
Hey sunnibeach4,
On SLR cameras the filters are attached to the end of the lens via threads inside the end of the lens barrel. Without knowing exactly what lens you are using I can't tell you what filter diameter you need but most lenses list that information on the inside rim of the front of the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 09, 2008
  • 14 Answers
SOURCE: MINOLTA MAXXUM 300si
Try www.flcamerarepair.com No chg. for ests.
Posted on Jul 31, 2008
  • 44 Answers
SOURCE: Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Posted on Dec 12, 2008
SOURCE: can you tell what battery
try to get 2cr5 it works :)
Posted on Nov 22, 2010
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Battery problem with a minolta dynax 300si
problems with the Minolta Dynax 300si Battery
Oct 27, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta maxxum 300si (Filters?)
Hey sunnibeach4,
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta maxxum 300si 35mm camera battery
Jun 28, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Film advance
It usually is the shutter not firing therefore jamming the advance. Try www.flcamerarepair.com They do not charge for ests.
Auto focus will not focus. lens problem or camera problem?
A dirty filter, front, or rear optic can cause the lens to seek
Feb 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Mounting a teleconverter on a minolta camera
AS you have found out, the Maxxum AF mount and the MD mounts are much different. They do make tele-converters that allow the use of MD (non-AF) lenses on a Maxxum series camera. You would still need another adapter to make the MD Tamron converter work,
Jan 06, 2008 | Cameras
Minolta Maxxum 300si 35mm SLR Camera Logo
21 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
