Question about Intel Motherboard
Vga problem - Intel Motherboard
  • Joel Navarro May 11, 2010
    Whats the problem?
    Sergeant:
  • 320 Answers
Did you tried using another monitor? ok if same problem occurs then you need to replace the VGA card. you will get it in the market. This card can be inserted in PCI, PCI express slots...
Thank you......
Posted on Jan 29, 2009
I have HDMI laptop and Dell 1706FPVT 17" VGA monitor. I have VGA to HDMI cable and I connected the cable between these two machines but it is not working. Solution, please.
First of, a little bit of explanation.
VGA = analogue
HDMI = digital
The answer seems to be in your question.
it reads "VGA to HDMI". These cables or adapters doesn't work the other way around. I am guessing your cable can only support vga output to HDMI input. And your setup is HDMI output from your computer to vga input to your monitor.
Solution:
Try and find HDMI to VGA cable or adapter. This is expensive.
If your computer has a vga output, use this with vga to vga. You won't get a better resolution by using HDMI to vga.
Or are you stuck with only HDMI output?
There are adapters for USB to VGA too. This could be less expensive. I have one for my friends Apple Air. I am not a "i" fan so I do not have much experience on Apple.
Hope this helps.
May 04, 2014 | Dell 1706FPVT 17" LCD Monitor
What cable do I use to get a G0773 Graphics card (Dual VGA/Single Port) to work with a single Acer P215H Monitor?
check vga cable or VGa card for enhance of video for more tips sign in ghulam rabani
Oct 23, 2012 | Dell G0773 Video Card
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
I need vga in my system now. how can i get it
VGA can be added to your system by buying and installing a vga graphics card, however some motherboards do already include a vga port
Dec 15, 2008 | Toshiba VGA Board Graphic Card
Dvi to vga
You will not benefit from the DVI input unless you have DVI output on your computer. The great advantage of DVI is that the picture is transferred in digital form all the way from your computer to the individual pixels on the monitor. If you only have VGA output on your computer then you will never get a better picture than by using a good quality VGA cable to link that to the VGA input on your monitor.
The DVI plug is designed to carry both digital and analogue (VGA) signals on the various pins, so "adaptors" exist to allow a VGA monitor to attach to a DVI output on a computer. Monitors may also support VGA input from their corresponding DVI input sockets, but the picture quality will never be better than by using a good VGA cable because it is still not using the digital capability of the DVI interface. What's more, because you may need more adaptors and thinner conductors in the cable, you will probably achieve a marginally poorer picture than with VGA to VGA.
When you next buy a PC or a new video card, get one with DVI to take advantage of your new monitor. In the meantime, your best bet is a quality VGA to VGA link.
Sorry that's not what you were wanting to hear, but I hope it will help you avoid further frustration.
Sep 20, 2008 | Envision EN-985e Monitor
Monitor not working
sorry friend i ws lill busy so could not rply.
Anyways
  • This is the VGA out: ebc4b94.jpg
  • And this is the connection for VGA comes from monitor: c99e5d1.jpg
  • Now if your VGA - Out is mounted on your motherboard then you have on-board VGA card.
  • means you have PCI VGA card.
Now if you want to use another PCI card just remove the one which you are using and use another one. Use only one PCI card for VGA, need not to use more than PCI VGA card at a time.
Thanks
Iqbal
May 13, 2008 | Computers & Internet
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Intel Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
