Question about Graco MetroLite LE Compact Stroller in Samba - 6125SMB Standard Stroller
Graco Metrosport stroller Model No 611198E
This is a six-year old stroller by Graco. The push handle is fixed (and adjusted for height) through a plastic knuckle joint to the frame of the stroller. The plastic adjustable joint has broken on both sides of the handle. Can I obtain a replacement pair of joints? I have had it welded - but the welding did not hold. Can the plastic be glued - maybe using a plastic model cement? I'd really appreciate your suggestions.
  • Michael Bevan Jul 26, 2007
    locking the joint will make the chair too long to fold into the back of the car
    Novelist:
  • 135 Answers
I'm sorry to have to tell you this, but Graco has refused a request to sell parts for that model of stroller. They didn't come straight out and say it, but the suggestion was that I should "buy a new model" of stroller. I was also unable to find any aftermarket company that sells replacement parts for that stroller. In fact, it appears that no aftermarket companies claim to sell parts for Graco products, so I'm guessing that they're worried about being sued. A suggestion for a workable solution to replace these joints would be to drill through these tubes and put a bolt through the holes and hold it in place with a wingnut. This would allow you to fasten it securely, yet be able to collapse the handle when you need to. However, to answer your question, yes this could be glued. Go to Home Depot and look in the paint department for the "adhesives" section. You're looking for a two-part epoxy that's made especially for plastics. Asking an employee for "plastic epoxy" might help if you don't find it. You mix the two parts of the epoxy glue together, apply this to both pieces and stick them together. I prefer the type that sets up in 5 minutes, since you then don't have to parts together for a long time before they are stuck firm. I believe the product is fully cured in 24 hours, but follow all package directions. this 2-part epoxy is probably the strongest type of adhesive you could use for this repair. Hope this helps, though I'm sorry for the bad news with graco. :\
Posted on Aug 06, 2007
  • 944 Answers
Contact these guys for replacement parts; http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11 Hope this helps :)
Posted on Jul 27, 2007
  • 705 Answers
How about drilling two small holes through the joint and fixing it with a couple of self tapping screws?
Posted on Jul 26, 2007
SOURCE:
Carrier manual
We'd recommend you contact Graco for assistance
Help Center Graco
Aug 14, 2014 | Baby Gear
I need the handlebar wires that make the height adjustable handle work on the quinny buzz 3 any ideas?
Hi - The wire from inside the Quinny Buzz handlebar isn't available as a seperate spare part item. To replace it, the entire handlebar is required, which comes complete with the inner workings. How old is your Buzz? If it is under 2 years old, please contact your retailer with your proof of purchase to make a claim under the terms and conditions of the warranty. If it is over 2 years old or you do not have proof of purchase please contact the customer service department for your country - for the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Nov 28, 2011 | Quinny Buzz 3 Stroller
Can't open graco stroller
  • press the 2 red buttons
  • kick the spring
  • pull the seat out
  • press the look on top
  • push the seat out
  • aim only 10 years old i bought the graco stroller for my 2 dolls it a real stroller
May 01, 2010 | Graco Alano Travel System 7F08DSW3...
I have a winnie the pooh graco stroller theres these red like adjusters by the handle what are those for?
i have a graco pooh stroller and i dont know how to put it up so my child can sit up shes a year and a half
Jan 01, 2010 | Safety 1st Acella LX Winnie the Pooh...
Graco lite rider navigator SL stroller broken seat holder clip
I've got a navigotor stroller and I can't unlock the back wheel brake or fold it
Dec 09, 2009 | Graco LiteRider 6712SFT Stroller
Adjusting seat in graco stroller
Our was an older model, but we just pushed it up and it clicked into place.
Sep 22, 2009 | Graco Quattro Tour Travel System
How to attach graco car seat safely to the duoglider
Yes. You will need to make sure you have one of the two tray tables that attach to the seats. Without this, you cannot use the Graco infant seat.
If you have the tray table, ensure it is attached firmly and properly to the stroller frame. Attach the Graco infant carseat facing the rear until you hear that it snaps in. This process is similar to snapping the carseat into the base that is in your car.
Jun 14, 2009 | Graco DuoGlider 7924 Twin Seat Stroller
I don't know how to close the Graco duoglider
I believe that this model has a little switch built into the handle bar (just underneath the handle bar you hold onto when you are pushing the stroller). You turn, slide or push this little switch at the same time as pushing the handlebars forward. Be firm and this will start the folding process.
May 22, 2009 | Graco DuoGlider Stroller Safari Sun...
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
I cant adjust straps on my graco metrosport pushchair how do i do it?
there is a board in the back of the stroller covering with the straps attched to it. Peel back the velcro and you can access the straps from there.
Mar 02, 2009 | Baby Gear
Graco MetroLite LE Compact Stroller in Samba - 6125SMB Standard Stroller Logo
375 people viewed this question
Top Graco Baby Gear Experts
gggg
Vincent G
Vincent G
Matthew Boulden
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
