Question about Whirlpool Dryers
Glo plug/ignitor will not light
I have a dryer wirlpool model #LGR 5636EQ2. We have checked all connections. Ran continuity checks on all wires and sensors. Ignitor has continuity between wires. We have the gas disconnected but I don't think that should stop the ignitor from coming on The motor runs the timmer runs the door switch works the pust start button works. HELP!!!!
I went on other web sights and found some helpfull information that was able to direct me to locate the source of the problem.
Posted on Jan 29, 2009
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
I have a KBNU367TSS and I am having problems with 3 of the 4 ignitors. Two of them will not work at all and one of them gets red but not hot enough to ignite the gas. The rear burner ignitor works fine....
One problem with glo plug ignitions is the loss of voltage across the glo plug. Each glo plug has to have the correct amount of current to get hot enough to light the gas. If the current is to low, the plug will glow, but not light the gas. You have to open the grill up and check the wiring, etc for shorts, bare spots in the wires insulation, etc.
Mar 19, 2011 | KitchenAid KBNU367TSS Gas All-in-One Grill...
Dryer tumbles no heat
remove the top cover,then the front cover,then check the burner tubes ignitor or glo-bar that ignites the gas,the high-limit thermostat on the burner tube for continuity,the thermal fuse and cycling switch on the blower housing both of these should show continuity or good like a standard fuse would show
Nov 18, 2010 | Kenmore 74642 Gas Dryer
Whirlpool dryer model #LGR 8620 pwo runs but only heats sometimes.
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 14, 2010 | Whirlpool LGR5636L Gas Dryer
Drum turns but does not heat the air. I replaced the ignitor, but no help there. Whirlpool gas dryer model 63003W0
If the ignitor glows but does not light the burner you need to replace the gas valve coils.
If there is no glow you must check all the thermostat safeties and thermal cutout fuses for continuity with a ohm meter. No continuity is a bad component. Remove at least one wire from each component before testing.
Unplug the dryer before any test.
Feb 17, 2010 | Whirlpool Dryers
Spins no heat on my wirlpool gas dryer
Check ignitor (glow plug). Replace if it does not glow when dryer is started.
Jul 08, 2009 | Dryers
I ran the drier 3 times using medium press. The heat is on and it is hot, but the clothes is not dry.
Hi, Does this dryer heat at first and then stop heating late in cycle?
Remove the lower front panel and start the dryer. Look and see if the ignitor glows and if you get a flame or not. If the ignitor glows and then shuts off before you get a flame, the coils on top the gas valve need changed.
If the ignitor does not glow, UNPLUG the dryer and check the fuse located on the blower housing (whits with two wires going to it). Check and see if it has continuity to it.If there is no continuity, change it.
Please let me know if this helps you so far.
Vic
May 30, 2009 | Whirlpool GGQ9800PG Gas Dryer GOLD...
Dryer turns but no heat and knob doesn't move
Check the switch on the motor. It may have failed, or has a wire/terminal broken/disconnected. It is a multi-contact switch. both sections must click. Could also be mechanically loose on the motor and therefore just not getting fully activated.
Hope this is helpful.
Apr 04, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer not heating up
remove the back panel and check the thermal fuse ( its white maybe 2inches by half inch 2wires leading to it. the most common problem. if thats good( a continuity test will tell,you want continuity thorugh the fuse).then i would check the ignitor assy.that s check also with continuity test, you can also checkt he plug leading to the ignitor for 110v, ifyou got powerr there and ignotir doesnt light you will need ignitor
Mar 13, 2008 | Dryers
Gas dryer with no heat
check the ignition might be a glo-bar element or a maintained high voltage spark module. once there is a pilot a flame rod or a millivolt generator opens the main valve for fire.
Sep 03, 2007 | Whirlpool LGR7646E Dryer
Dryers Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
