Question about Kenmore 98702 Stacked Washer/Dryer
Drier does not heat up.
I have a kenmore stacked washer drier electric. Everything works except the drier does not get the hot air/heat. I opened the back. The heating element seems to be okay, it is not burnt or broken.
  • maloneydad Jan 29, 2009
    I opened the middle piece and found the gas line coming in. I noticed a lever on the gas line the rotates 90 degrees. Which direction should the lever be in for gas to make it through the line? Is this my problem why I cannot get the dryer to heat up?:
    Joe
    maloneydad@gmail.com
  • Anonymous Mar 02, 2009
    Dryer spins, but doesnt heat up. I cleaned out the lint trap and asked maintenance to unclogg the filter if needed, but still no difference. How can I get my dryer to heat up and where would I order the part from if needed?
There is a white fuse (sometimes called a limit) in the back of the unit. It is about 1/2" wide and about 2" long and it has connected by two clips and terminals. Replace this and you should have heat. It usually blows when there is too high of a build-up of lint in the unit. Before you put it back together, clean all the lint out of it including behind the lint trap.
Posted on Feb 07, 2009
    Problem Solver:
  • 18 Answers
In order to test the element, you will need an ohm meter. It should test at 8 - 12 ohms. If it is not the element, it could be any of you other thermostats, here's a rundown: thermal fuse. It is white and about an inch and a half long and had two wires going into it. Thermal cuttoffs, one is right next to the element, and the other is further above the element. If one of these is bad, you will need to replace them both. the last is the thermostat with heat anticipator. this thermostat will have four wires going into it and is located right next to your thermal fuse. To test any of these thermostats unplug the wires leading to them and test each lead with your ohm meter, if you have steady numbers or 'countdown' it is fine, move on to the next. once you reach one that reads 'ol' or 'open line' that is the thermostat that is bad. Good luck and happy fixin'!
Posted on Jan 29, 2009
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
Hi, Dryer cycles are working perfect, except there is not hot air...only cold....problem? and easy fix please? Thanks.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 02, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer works fine dryer does nothig
Looks like my Maytag. My dryer belt is broken so doesn't tumble. Check by taking two screws out of tilted panel and look at belt. If it isn't heating probably heat coil. If nothing probably electrical. Maybe door switch is open circuited.
Jan 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
145 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
