Question about HP PSC 2410 All-In-One InkJet Printer
Printer wont align
I had changed my ink cartridge and after that i know that i need to align the printer. but it wont align. the keys "fax", "copy", "scan" and "photo" are all lighted up at the same time and it's not suppose to. actually all the keys are not functioning. now, i'm not able to use my printer by itself. i can still use it so long as i use it with my computer through the hp director. and the screen on the printer just keeps on saying that it needs to be aligned.
  • anna arellano Jul 26, 2007
    no, i tried that already. after i press align via my computer, it starts to print but then gives an error message that there's a paper jam when actually there's not. after i click on "ok" 2x, it just cancels the printing/alignment. i have to click the "ok" to let the printer know that i've cleared the paper jam eventhough i really did not. by the way, that error message paperjam just started after i changed the cartridges. everytime i need to print something, that error msg appears and after i click the "ok" 2x, i'm able to print whatever i'm printing but it doesn't work for the alignment.
Problem The following error message appears on the color graphics display after you insert a cartridge: Align Print Cartridges. Press OK to Print Align Page . You press Enter , but the error message does not go away. The printer will not print. Solution
  • To simply bypass alignment, do the following:
    1. Press and hold the Setup button.
    2. Press the Up Arrow button. The printer should be ready to print.
Posted on Nov 21, 2007
  • HP Master
  • 691 Answers
Can you complete the alignment through the maintenance tab on the driver via your computer?
Posted on Jul 26, 2007
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Canon MF4360-4390 Printer/Scanner/Fax We are
I am not able to send faxes/memory is full and I don't know how to reset
Sep 23, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
I have printer x2500, when the unit is power on, the ink device goes from left to right hitting both end and stay in the extreme right side, and do nothing. There is any alignment procedure??
Hi
Usually the alignment process executes when the ink cartridges are changed or replaced .
There is a way to print the alignment using the printer drivers in the printers and faxes folder.
let me know if you need further assistance
Jul 14, 2009 | Lexmark X2500 All-In-One Printer
Will not fax
Hold down the enter button 1rst then press the setup button. This will bypass the annoying align cartridge problem. For some reason it does this because the cartridge you bought was refilled then sold again. Your welcome!
Apr 08, 2009 | HP PSC 950xi All-In-One InkJet Printer
How come Alignment of Cartridge needs at each printing?
I just go ahead to print and do with what the printer wants me to do. Because I just bought 2 black cartridges, when I use them up, I will buy another printer, different brand, I regretted that I bought Lexmark printer, the ink tube is so little and very expensive. I wish I still had the previous printer . It was still good and new, it has bigger ink tube (1 1/2 times) but the only reason I turned it down, because it was only for printing & copy, it does not have scan or fax which I very seldon use those. Thank you anyway.
Feb 05, 2009 | Lexmark X8350 All-In-One InkJet Printer
Ink levels
on the printer reset the ink levels and in the sofware , otherwise the cartrige is to old and just wont register correctly
Oct 08, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
HP PSC 2410 All-In-One InkJet Printer Logo
402 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
