Question about Storagetek L40 DLT Tape Drive
StorageTek L40 Tape Library
Could someone please tell me what caused the following error and how I can fix it: The range of motion on initialization is not within specification (308F)
  • 661 Answers
Sounds like your robot is stuck or something may have dropped onto the track on the floor which is restricting it's movement.
Posted on Aug 06, 2007
How to change backup tape in storagetek L40?
would appriciate very much if you could reply me!
Thank you!
Posted on Apr 08, 2008
9E 09
Hi Alan
Error 9E - Elevator range of motion out of specification
The Elevator (the part of the robotics assembly that moves in the vertical direction) range of motion out of specification
If possible, check for an obstruction by powering off the library and either removing a magazine or a drive to view the robot. Gently remove the obstruction, replace all magazines and drives and then power up the library.
Re-try the last operation
If you are in the UK and are still having trouble, please click the link below and we will do all we can to help you.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 27, 2014 | IBM Computers & Internet
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
Proximity detector off failed
Hello!
I had the same problem with our Storagetek L40 library and had to get another robotic hand from a company named Instock Inc.
It was an easy fix. I just had to power off the L40 library, take off the old hand and put the new hand on, then turned the L40 library back on, and it worked great after that.
In the hand is a sensor that goes bad after time.
You should be able to find them on the web at instockinc.com I believe, and they should have the hand you would need.
Jan 26, 2011 | Storagetek L40 DLT Tape Drive
StorageTek L20
Yes, you can open the CAP. I believe the menu has a function for that, like Select to Open CAP.
Apr 02, 2009 | Storagetek L20 DLT Tape Drive
StorageTek L20 SCSI ID issues?
Did it ever work for you?
You don't have to assign the scsi id's on the drives. The L20 does that for you according to whatever you set in the drive config menu.
When you say the system 'forgets' the id's does that mean it saw them initially? Does it lose any particular one or all of them? What's the physical configuration - that is, what devices are on which scsi busses and what are their ID's? Any daisy chaining?
Is there a router in the mix somewhere?
Nov 03, 2008 | Storagetek L20 DLT Tape Drive
Error Code 3112
3112
ERR_ITL_DETECTOR_OFF_TEST_FAIL,
The test for the proximity detector off failed.
FRU: LOCATION: CONFIDENCE %:
HAND ASSY LSM 90
LLC LCU 10
Check the hand
Aug 27, 2008 | Storagetek L40 DLT Tape Drive
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
Service required led blinking
You will need to get a StorageTek engineer out onsite to have a look at the problem, the light will not dissapear until resetted by a engineer.
Jul 10, 2007 | Storagetek L80 DLT Tape Drive
Sn 3250 router problem
Ok, I'm confused... are you sure this isn't router that you're mentioning isn't a SAN Switch? A StorageTek/Brocade 3250 switch... and this is a StorageTek Scalar 100 Tape Library with Fibre aware LTO Drives. The Library Users Manual can be found at http://downloads.quantum.com/scalar/S100/omS100UsersGuide.pdf. Switch information can be found at http://www.storagetek.com/products/product_page2304.html. I'm not a Sun guy, so I would suggest that you contact them to find out which versions of firmware for the switch that they have certified. With HP, there are certain versions of firmware that they certify with HPUX... and specific versions of HBA drivers that work better with HPUX as well. If it is, in fact a Brocade 3250, I would suggest that you start with a "switchshow"... figure out which port drive 4 attaches to... do a "porterrshow #" (# represents the port found) to see the port error statistics... you want to check the loss of signal and link failure count. I would do an "sfpshow #" to see the status of the transciever as well. Let us know.
Oct 04, 2006 | Storagetek StorageNet Router 3250
Storagetek L40 DLT Tape Drive Logo
450 people viewed this question
Top Storagetek Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
