Question about Metra Ford Premium Sound System Amplifier Eliminator Plug (70 5513)
Trying to hook up aftermarket radio 98 windstar limited.
I got power to turn on and off but cant get the speakers to work. It has the ford premium sound system. I thought I had the speaker wires butto no avail.
    Problem Solver:
  • 6 Answers
If this model has an amplified system, then you may need a different wiring harness. The harness you purchased may be for the non amplified model. Try that, and let us know.
Posted on Jan 29, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
I have a 98 escort se and the radio was working
sound like the radio died, rpelace it with aftermarket.
Oct 19, 2014 | 1998 Ford Escort
Rear speakers dont work
The most common problem is the rear speaker Channel goes out in the radio I suggest buying a aftermarket radio And installing it or going to a junkyard to get a factory radio
Mar 11, 2014 | 2001 Ford Windstar
I have power everything works no sound out of speakers I even hooked up seperatly to a speaker I know works still no sound all wires hooked up correctly also have no gps signal showing red satelite can...
Many radios today have a security system that renders the radio inoperable should they be stolen or removed from the vehicle. If this radio is from a different vehicle, it may have a security code that needs to be reset.
Feb 21, 2013 | Cars & Trucks
Ford stock amplifier
need to wire the power wire for the amplifier to the remote wire on the aftermarket radio usually a blue wire on the after market radio
Feb 20, 2013 | 1998 Ford Expedition
Just put an aftermarket stereo in my 2000 ford windstar. I used the specified harness adapater for this vehicle. The new stereo works great. However, now my 2 back speakers dont work at all. What could...
Definitely. The specified harness adapter you used makes no provision for connecting the rear seat control unit. You may be able to modify the adapter wiring to connect to the rear speakers.
Jan 14, 2018 | 2000 Ford Windstar
Radio wires differ from the speaker to the radio
This is the most common problem with self installs.The best thing to do is to get the car radio installation plug,it will plug into the factory plug for your factory radio and will give you a color coded pigtail to wire into that usually matches up perfectly with new aftermarket car radios.If the wires are already cut then you best bet is to extend the wires so that they are easy to work with hookup the power,ground,antenna and try dirrerent combos to isolate each speaker and label the wires accordingly.
Jan 01, 2010 | 1998 Ford Windstar
Rear door speakers not working in 98 tahoe
Your aftermarket radio may only have a 4 channel amplifier and will only be able to power four speakers. The only way of having the other speakers work would be to wire in an external amplifier
Dec 16, 2009 | Car Audio & Video
98 ford windstar no dash and tail lights
you have to check all fuses with a test light both fuse boxes under hood and under dash... if good next to look for is the light switch itself... has any radio work been done to the lately... if so alot of times hooked up wrong will blow park fuse as one of the wires to radio is the park voltage to tell radio to dim down some
Sep 06, 2009 | 1998 Ford Windstar
Metra Ford Premium Sound System Amplifier Eliminator Plug (70 5513) Logo
456 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
