Question about Polaroid FDM-1000A 10" Under-the-Cabinet LCD TV with DVD Player Television
26" 720p HDTV/DVD COMBO will not eject disk
I put in a cd and played it,then pressed stop, andtried to eject the disk. It will not eject.
  • 2,071 Answers
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope it may help you;
Posted on Jan 29, 2009
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dec 02, 2012 | Televison & Video
Dvd will not eject and noisy
To eject, put a staple on small orifice on the front.
Or, by the Explorer window, go to letter of DVD, and with right mouse button, click on "eject".
Have any disk inside? Maybe the disk have some problem to do the noise.
Sep 18, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Toshiba Regza 32 inch with DVD player - won't eject
Disconnect cable from DVD to TV, press play, and then press stop, try to push eject button to get the disk out. If all could not have, you have to open the DVD cover then get the disk out.
Aug 18, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Zenith XBV243 CD player keeps ejecting disk
You may need to try a cleaning disc to remove dust from the laser heads, as dust may be impeding the player from recognizing the disc type.  Also, double check the manual to see what disc formats your player can handle.  All players have a variety of formats they accept or reject.  If the owner's manual verifies that it does accept that CD format, try the cleaning.  If that doesn't work, it may an issue that will require an authorized service center to look at, which may not be work the cost as replacement DVD players are very inexpensive.  Avoid combo players such as the DVD/VCR combo, as when one quits performing, you either have to replace the entire unit or add a new single component for the bad one.  Hope this helps!
Dec 06, 2008 | Zenith XBV243 DVD Player/VCR
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Polaroid FDM-1000A 10" Under-the-Cabinet LCD TV with DVD Player Television Logo
222 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
